N
[email protected]
- Jan 1, 1970
- 0
Gary Reysa and I are now exploring a greywater heat exchanger with 3 100'
PE pipes (cut from a $60 300' piece) inside a $30 100'x4" corrugated black
plastic drainpipe vertical helix wound around a 2' square x 6' tall bolted
2x4 frame with a 4" horizontal thinwall PVC T at each end:
Warm greywater would enter the upper vertical side arm of the upper T and
cool greywater would leave via the upper vertical side arm of the lower T
and flow up into a vertical 6'x4" pipe and out the top into a septic system.
Cool fresh water would flow from a garden hose in through a cap at the end
of the lower T and up through the 3 1" pipes, and warm fresh water would
flow out from a cap at the end of the upper T into another garden hose and
into the drain tap of a conventional tank water heater.
The PVC Ts would meet the Hancor corrugated pipe with a $16 Fernco 1070-44
fitting. This 4" rubber sleeve has 2 hose clamps and a molded O-ring on
one end which fits into a pipe corrugation. It says "Overtightening of
clamp on this end of the coupling can collapse pipe wall," but it looks
like sliding a $1.28 3" thickwall PVC pipe coupling inside the corrugated
pipe will allow a waterproof 3 psi joint. As a cheaper alternative, this
might also work with a $5 Fernco straight 4" coupler.
So far, the hardest part is dividing the fresh water into 3 pipes with
an inexpensive manifold at each end that will slide into a 4" PVC pipe.
(Ferguson sells 6" Ts and 6"-4" reducers for $19 each!) Here's a Lowes
parts list for an equilateral version that clears a 4" pipe by about 1/4":
Qty Part # cost description
1 PP25052 2.04 3/4" MHT-3/4" FIP brass hose adapter
1 436 007 0.27 3/4" PVC male adapter
2 401 010 0.76 3/4" PVC Ts
2 409 007 1.48 3/4" PVC street elbows
3 437 131 1.41 1"x3/4" PVC bushings
3 436 010 1.32 1" PVC male adapters
3 435 010 4.86 FPT-1" grey PVC barb adapters
1 49303 0.32 2 1"-3/4" reducing galvanized conduit washers
3 105 733 4.29 6 3/4"-1.5" SS hose clamps
$16.75 total, per end
The hose adapter and 3/4" male adapter would screw together through a hole
in a flat 4" PVC endcap, clamping the conduit washers and a rubber washer
to make a low-pressure bulkhead fitting. Trimming the Ts and elbows might
increase the 4" pipe clearance to 3/4". The lower T would have a male hose
thread and inline valve protruding to backflush the greywater path, perhaps
once per year.
This lacks the desirable thermal stratification of a drum heat exchanger
with different greywater inlet temps (altho our tests didn't show much of
that), but it's simpler to build. The 1" pipe holds 12.5 gallons of water,
so this might be close to 97% efficient (saving ~$300/year) with smaller
hot water bursts or a slow greywater flow, as in a chemical-free hot tub
with continuous water exchange. Something like this would also help:
http://sunfrost.com/efficient_shower.html.
Nick
once per year.
Nick
