Hall Effect Sensors
Michael
I'd like to interface Hall Effect sensor to a uC and have picked out the
A1301EUA-T (datasheet:
http://www.allegromicro.com/en/Products/Part_Numbers/1301/1301.pdf ) with no
particular reason - just seems easy to get hold off.
Now based on the graph at the bottom left on page 5, am I right in thinking:
Output from HES fed through a non-inverting amp. with gain of 250 would
produce a voltage of 625mV at 1G when the supply voltage is 5.0V? It just
seems a bit too easy (I'm guessing changes in temperature etc are going to
have a significant effect but right now just trying to get hold of the
basics.)
If I told you the application was going to be a motor tachometer - is it
'better' to feed the (amplified) voltage through a comparator and so convert
the analog signal into digital signal (when above a theshold go high, below
or at theshold go low type setup) or feed it into a ADC pin and work out the
digital signal using software? I'm worried that if I tied that to a ADC pin
then it could go over the pin's max voltage (5V) so would I need something
along the lines of a zener diode to dump any 'extra' voltage over say 4.5V
to be on the safe side?
I've only just started learning electronics so don't know if the circuit's
above are 'suitable' and so would appreciate any help. ( It's not a homework
assignment :) )
Apologies if that's a few too many questions.
Thanks in advance,
Michael
Jamie
Michael said:
basics.)
assignment :) )
Thanks in advance,
Michael
I wouldn't worry to much about going over the voltage of the ADC pin how
every, I would be concerned about the response time of the ADC when
using it as a tech (HI speed input)..
you would be better to use a simple Op-amp with hysteresis, or I
think the input's of the PIC already have some hysteresis in them, so
you might be just fine.
I would look into assigning an input to one of the counters in the
micro. (High Speed COunter).
Chris
A1301EUA-T (datasheet:http://www.allegromicro.com/en/Products/Part_Numbers/1301/1301.pdf) with no
basics.)
assignment :) )
Thanks in advance,
Michael
Hi, Michael. In fact, it's not so simple, and unfortunately, I think
you've taken a wrong turn here.
The nominal output of the sensor you're looking at is around 1/2 Vcc
(around 2.5V for a 5V supply). Now apart from any drift caused by
variations in supply voltage, you'll have to apply the sensor output
voltage to an op amp to subtract out the 1/2Vcc.
The data sheet says this quiescent output voltage is stable over time
and temp, but considering you're talking about such a small sensing
voltage to begin with, you are heading for problems here.
The good news is that there are hall effect sensors with digital
outputs that react to the presence of a magnet quite nicely, and will
have fast enough reaction times for a tachometer. You can forget the
analog stuff, hang a pullup resistor at the output of the sensor, and
just count the digital pulses. This is how it's done.
If you'd like further information or need help in sensor selection,
please post back with more info.
Cheers
Chris
Michael
Cheers
Chris
That sounds perfect - any keywords I should be using?
Michael
Chris
Michael- Hide quoted text -
- Show quoted text -
Hi, Michael. Since you've found a UK distributor for Allegro, I'd
suggest just going to the Allegro Unipolar Hall-Effect Digital
Switches page, and taking your pick. As I said, just have a magnet go
past the IC, use a 1K pullup, and just read the digital output with
your uC. If it's a very fast application and you don't have a
hardware counter on board, you might want to use a flip-flop to make a
divide-by-2 counter, then you can just see every transistion as 1
revolution.
http://www.allegromicro.com/en/Products/Categories/Sensors/unipolar.asp
You could do worse than choose one of the A1101-1104 and A1106 family:
http://www.allegromicro.com/en/Products/Part_Numbers/1101/1101.pdf
For all you want to know about digital unipolar hall effect sensors,
look at the appnote listed on p. 8, the Hall Effect IC Applications
Guide:
http://www.allegromicro.com/en/Products/Design/an/an27701.pdf
Cheers
Chris
jasen
If it's to be a tachometer on a gasoline engine the best way is a 1M resistor
from the switched terminal on the low voltage side of the spark coil.
assignment :) )
If you want to use a hall sensor it may be easier to use one with a
digital output eg: take the phase sensor from an old computer fan.
It's better than too few.
Bye.
Jasen
Michael
revolution.
Guide:
Cheers
Chris
Thanks Chris, that's perfect.
Is there an IC with a single flip-flop on or are they abit like socks?
Michael
Chris
Hi, Michael. For a bit more cost, you can get a bipolar hall effect
sensor, that will turn on in the presence of the south end of a
magnet, and remain on until in the presence of a north. If you can
arrange two magnets of opposite polarity at 0 degrees and 180 degrees,
you'll have the whole solution.
http://www.allegromicro.com/en/Products/Categories/Sensors/bipolar.asp
Cheers
Chris
Michael
Cheers
Chris
Yeah I noticed those in the app notes I think they called them latching hall
effect switches.
I take it these also need a pullup resistor?
Now I guess I have to choose one....
Cheers,
Michael
