[email protected]
- Jan 1, 1970
- 0
A little background on this process.
Take 208 VAC 60HZ. Hook up to a small SCR voltage controller for
variable voltage. Out to a full wave bridge rectifier. Hooked up to a
resistive 35-50 Ohm load.
Here's the problem. I'm dropping to about 180VDC max at the load
because there is no ripple filtering. I need a much higher voltage. I
want to get this higher voltage by using a capacitor(s) across the
output.
However, I have no idea what value Capacitor to use. I've searched the
web and can't seem to find any calculations thet will help me. I know
it will be high uF due to the voltage and current ~4-5 amps. It
bascially is just a simple DC power supply but I can not find info on
a supply with this high of voltage.
Any ideas???????????
Thanks...
output.
Thanks...
