Help choosing a stepper driver
W
webzila
My group and I are working on a project where we plan to operate a door
(open/close it) with the following voice recognition system & relay:
http://www.imagesco.com/catalog/hm2007/SpeechRecognitionKit.html#sri-02
Obviously we will need either a stepper motor or a dc motor to actually
open/close the door. We looked at some stepper motor kits but most are
operated by dip switches or jumpers but the whole point of our project
is hands free operations.
The voice recognition system has 10 relays (1 for each word that it is
set to recognize). Can someone recommend a good/cheap stepper motor
driver circuit or an IC that will be able to interface with the relay
that I posted above and open/close the door at a specified speed.
Any input/help would be appreciated.
Rich Grise
It looks like you have on/off control. You don't need a stepper or
any kind of controller. Well, depending what your outputs look like.
If you have, say, a pulse, then use two relays - one for "open" and
one for "close", and cross-couple them so it's bistable, and put
limit switches at the ends of travel. Then just use any old motor
and gear/belt/cog arrangement moves the door right. :)
Any old _reversible_ motor. ;-)
Cheers!
Rich
Steve
Thanks for your reply.
So you are saying that if I use a reversible motor then I wouldnt need
a driver?
I have to check on what kind of output the relay produces. From what I
can see each numbered relay has a single-pole double-throw (SPDT)
switch rated at 125 VAC at 0.5 amps or 24 VDC at 1.0 amps.
Here is a pic of the relay (dont know if this shows or tells you
anything):
http://www.imagesco.com/images/catalog/sri-02.jpg
So with this type of relay you are saying thats its possible to use a
reversible motor instead of a stepper? How would the speed of this
motor be controlled? Also, how would you control when the motor should
stop turning (when the door is fully opened/closed).
Thank you
Terry Pinnell
a driver?
anything):
That's the interface board - no relays on it! The relay kit is shown
to the right as 'SRI-02' in the diagram you linked earlier:
(BTW, it seems to me those pages sometimes carelessly swap 'SR' with
'SRI'.)
Yes. Where did the ideas of a stepper motor arise?
How would the speed of this motor be controlled?
Ambiguous question. Do you mean you want to vary the speed *during*
each opening/closing? (Maybe to sort of tease the door user?) Or are
you asking how to set a fixed speed for some motor(s) which you've
presumably not tried and haven't described so far?
As Rich said, use switches to detect the extreme positions. A variety
of circuits are possible, depending on the detailed requirement. An
alternative would be detecting increased current when the motor tries
to take a leg off.
Here's one I used for a Window Opener I made many years ago, using a
surplus 12V windscreen wiper motor:
http://www.terrypin.dial.pipex.com/Images/AutoMotorExtremes.gif
A pair of N/C microswitches (SW1 and SW2) were carefully placed at the
two extreme positions so that they are respectively opened when the
window reached the fully open or closed positions. A SPDT switch (on
left of first diagram), controlled whether I wanted to open or close
it, and also BTW gave visual indication of the current state.
Another approach which I've used recently for my Curtain Controller is
shown here, and uses a bistable approach to control a screwdriver
motor:
http://www.terrypin.dial.pipex.com/Images/CurtainController1.gif
http://www.terrypin.dial.pipex.com/Images/CurtainController2.gif
Note that this one uses two N/O (not N/C) microswitches. And *two*
relays, one for power (on/off), and the other for direction
(forward/reverse). Various N/O push buttons allow either open, close
or (simpler) toggling, from either my wife's side of the bed or mine.
An external dawn/dusk circuit (not shown) allows operation via the
'Ext' inputs.
I haven't got around to detailed notes on this yet. (IOW, the sort of
notes I'll need 5 years from now to understand what the heck I was
trying to do!) But - with some assumptions about your group's skill
level - the relay/motor approach should be possible to understand from
these two schematics.
