Help! Datasheet for IX0217 LSI IC (Sharp) Required
I
Ian McOwan
Hello everyone,
I'm desperately searching for a datasheet for an LSI device ... marked as
IX0217 by Sharp (~64 pin, square, SMD). It appears to be a function and
LCD driver in a small hifi system.
Other package numbers include D753017A.
I've searched bucketloads of 'datasheet' sites, and Sharps sites but to no
avail :-(
If anyone could help it would be appreciated ...
eMail: [email protected]
Thank you :)
Phil Allison
"Ian McOwan"
avail :-(
** The only data you will get is what you can glean from the schematic for
the hi-fi unit it comes from.
You will likely have to pay someone to supply that.
........ Phil
Richard Freeman
Ian McOwan said:
Hello everyone,
Try UPD753017A - microcontroller with LCD Controller
It is most likely Pre-programmed (in other words if it is stuffed you will
need one that has been programmed ) and I am guessing that IX0217 is going
to refer to the software programmed into it....
avail :-(
Data sheet - try
http://www.eu.necel.com/_pdf/U10140EJ2V0DS00.PDF#search="753017"
However you will need a Programmed one from Sharp....
Regards
Richard Freeman
F
Franc Zabkar
Data sheet - try
Regards
Richard Freeman
The datasheet for the "A" version is here:
http://www.eu.necel.com/_pdf/U11662EJ2V1DS00.PDF
User manual:
http://www.eu.necel.com/_pdf/U11282EJ3V0UM00.PDF
- Franc Zabkar
