Help finding a part!!!
I'm looking for a simple electronic switch that will relay 120VAC at
60Hz and can be controlled by an external control signal (on/off). It
seems like something like this would be standard but I'm having trouble
finding it. Any ideas? The less expensive the better.
Thanks.
scada
Thanks.
More info needed. Is this to be used in a home? How much current is being
switched? Is the load inductive (motor, etc...)? Google "X10", it may work
for you if your criteria fits.
John Fields
In the first place, you ought to be asking that kind of question in
sci.electronics.basics, and in the second you ought to learn how to
use google for other than just posting to newsgroups.
Having said that, what you're looking for is called a "relay" and
they're ubiquitous. How much current do you want this "relay" to
control, and what kind of a control signal do you want to be able to
turn it on and off with?
K
Ken Taylor
Thanks.
Are you switching 120VAC, 60Hz, or do you want to switch 120VAC at 60 times
per second?
If the former, use a relay or contactor plus an electrician; if the second
we need more info.
Ken
