help needed to identify sot-23 transistor
The smd sot-23 transistor is marked as A009. This transistor is used
to control a fan speed in a buck step down converter. The transistor
is breakdown so that the whole 12V is applied on the fan. And I have
no idea what kind of transistor is it MOFSET or PNP
thanks
Eeyore
SMT parts of that size all have very abbreviated markings.
Good luck identifying it.
Graham
N
nobody
thanks
There is a search engine for surface mount package markings here, but it
is far from complete:
http://www.random-science-tools.com/electronics/SMD_markings.php
There is a site here with quite a few parts, but I couldn't see A009
http://clivetec.superihost.com/SMD_CodesA.htm
Remember that it could be a letter "o" not zero and sometimes the last
digit is the date code, not the device type.
Unfortunately, it is very hard to identify these parts from the code
they aren't even unique so if you do find one which is marked A009, it
may not be the one you want.
Can you work out what it is by looking at the voltages on the three
pins? Does it go between the fan and ground or the fan and +ve?
Good luck.
Robert Baer
thanks
It may not be a transistor; it is possible to have the whole switcher
circuitry in a SOT-23 package.
?PNP????
MassiveProng
Examination of the surrounding circuitry would prognose that.
OK.
?PNP????
You know... the opposite of NPN.
Alex
HI,
I meant bi-polar not PNP. The broken park is marked as Q317 on the
board. The one near by is marked SS which appears to be a MOSFET tr-or
and it is also marked as Q316. So I assume that Q317 is also a tr-or.
And seems like it is packed not into the SOT-23 but into the SOT-323
because it is a little bigger then the Q316
I'm attaching a scheme very sketchy one http://
petergof.googlepages.com/scheme.PNG
Honestly speaking it absolutely make no sense to me. So most probably
I've interpreted something wrong
Alex
What I'm 100% sure is that 12V is applied now onto the fan. Previously
+5.85V were applied on low load and 9.5V on full load.
W
Winfield Hill
It looks like a p-channel mosfet transistor to me.
Alex
I also thought about it. But then its source leg shall be on +12 and
not on the ground.
W
Winfield Hill
not on the ground.
Yes, its source leg is at +12, not ground, because it couldn't
work otherwise. It's a common circuit. The sketch is wrong.
Alex
um, seems like i have to disassemble my computer to perform some
measuring which is a bit of work. But thanks anyway.
N
nobody
Ben said:
That's very handy. I think I'll go add every SMT part I buy to that
just in case I need to ID them later myself!
Good idea. If we all did that we may have a chance of identifying these
things.
Tom Bruhns
http://www.tkb-4u.com/code/smdcode/indexsmdcode.php is another place
to look for SMT marking codes. They suggest than an A9 in SOT23 may
be a Siliconix SI2309DS, a P-channel mosfet. The Vishay/Siliconix
data sheet says the marking is simply A9, but another manufacturer of
an equivalent part may be marking them A0009. (That's quite a bit to
get on a SOT23, it seems like. Usually the codes are just two or
three characters.)
Cheers,
Tom
Robert Baer
Almost nobody uses a PNP, especially in a fan controller...
Robert Baer
Alex said:
HI,
Q316, Q317 etc have absolutely *nothing* to do with part type or
function; those are part designators.
The manufacturers PC layout and build kit list would have more info,
like "Q5 NPN 2N2222A,...R23 5K 20Watt".
Even markings *on* a part can be what i call "mouse numbers" meaning
"house numbers" which are not related to what they really are.
A number of large companies use their own internal coding system and
have standard parts marked (by the makers) to their specs.
Alex
linkis another place
three characters.)
Cheers,
Tom
Seems like you are right! Thanks a lot Tom!
