help, no picture on magnavox big screen
marks56
Hi all, I don't know much about these but I'll try. I have an olde
magnavox big screen model rh8524 ak08. it has power and sound but i
has no picture. now you got the cable that comes from the wall to th
tv, and on the other side of that plate there is a shorter cable tha
goes from the wall cable to a silver metal box on one of the boards. I
I mess (jiggle) that cable at the metal box the picture will come o
untill you turn off the tv, then you have to do it agian. obviously,
don't know enough to fix it myself, but I would like to know what th
box is called so when I get someone out to fix it, i will at least hav
an idea of what they are talking about! thanks, Mar
K
kip
Sounds like the Tuner has bad internal connections.
Needs to be removed and the cover taken off and
the internal areas need resoldering.
kip
marks56
kip
"marks56" [email protected] wrote in message
Hi all, I don't know much about these but I'll try. I have an older
magnavox big screen model rh8524 ak08. it has power and sound but it
the
tv, and on the other side of that plate there is a shorter cable that
If
I mess (jiggle) that cable at the metal box the picture will come on
I
don't know enough to fix it myself, but I would like to know what the
have
an idea of what they are talking about! thanks, Mark
thank you very much, ki
Erich J. Schultheis, The Man with the 15 inch Cock
has no picture. now you got the cable that comes from the wall to the
goes from the wall cable to a silver metal box on one of the boards. If
untill you turn off the tv, then you have to do it agian. obviously, I
box is called so when I get someone out to fix it, i will at least have
It's quite simple mark, you need to replace that cable. It sounds like
it might have a short in it.
