HELP! Temperature sensor
Michael
Babich said:
We made the temperature sensor with DS1621 and we have problem reading
temperature. It always displays temperature of -60 C (-76 F). (both of
them). We used following shematic
http://www.electronics-lab.com/projects/pc/010/
Please help us!!!
Sorry on my bad english
First of all, I've never used that DalSemi device. I have used only the
DS1820, but I've used it extensively. I've never read a DalSemi via COM
port, only with uCs. Nevertheless, some of what I write here might be
"all wet".
Your project uses a Win PC and COM port to read the DalSemi device(s).
There might be timing problems injected by Win. I know that DalSemi
1-wire devices have strict timing requirements. Have you scoped the COM
port and compared traces to sensor timing specs.? (I admit I don't know
that the device you're using is 1-wire; maybe it uses Data and Clock
lines. It's been a while since I read up on DalSemi temp. sensors.)
The temp. you're getting is (as I recall) the max. negative temp. that
the device can report, which corresponds to a large negative number.
Perhaps your sensor(s) are not responding at all. THe PC might simply
be reading a line that is normally high and never gets pulled low. Or
a device could be responding OK but the PC reads one or more bits too
early/late (Win timing problem). Or, if you're using addressing, that
address could be corrupted due to PC's incorrect timing.
Or ... all of your sensors are defective. This isn't such a far-fetched
idea; I once got three inoperative DS1820 from a distributer and found -
with DalSemi's tech. support - that *all* devices were defective.
I would go bug the guy who wrote the VBASIC code and ask for his help.
Anthony Fremont
1) Try it on another computer, preferably not a laptop.
2) Make sure you have +5V on pin 8 of each IC.
3) Make sure diodes are inserted in correct direction.
4) Check for good clock signal on pin 2 when temp measurements occur.
You should see a nice square wave bursts (0-5V at approx 100khz)
5) You should see (what would appear to be) varying width pulses on pin
1 when the clock is occurring on pin 2 during measurements. This is
your temperature data.
Your device uses the Phillips IIC protocol (AKA two-wire) to
communicate, not Dallas 1-wire as another suggested. Also be sure that
you are actually using a 1621 (obsolete) and not the replacement 1631,
there are some differences that may affect you.
Michael
I took a close look at the schematic of your beastie. Forget my
comments about 1-wire in previous reply; your sensor isn't 1-wire.
Nevertheless, if you're trying to address a sensor on a multi-drop bus,
make sure you're sending the correct address.
Can you read a sensor address OK?
Amnon Pomerants
Hi
SCL and SDA pins are usally used to drive the I2C protocol.
You have connected it to the COM port (RS232 protocol) of the PC.
Such connecton requires a SW above the RS232 protocol that will comply with
the I2C protocol in order to drive the SCL/ SDA pins properly.
a simple TERMinal PC program will not do the above.
Amnon
