HELP WITH DSC 2500 NO SIREN
1.HELLO, CAN SOMEONE TELL ME WHAT MIGHT BE THE PROBLEM, I TESTED MY
ALARM AND THE SIREN IS NOT SOUNDING. EVERYTHING ELSE WORKS FINE, NO
ERRORS SHOWN. ITS A WIRED SYSTEM. IS IT EASY TO REPLACE.
2. MY ALARM IS FROM 1989, WILL ANY REPLACEMENT 4 WIRE SMOKE DETECTOR
WORK ON MY SYSTEM, I WANT TO REPLACE MY 2.
THANKS AGAIN
Allan Waghalter
Try removing the wires to your siren and connecting them directly across the
battery. If the siren is good, it will work. If it clicks, you have a
speaker and not a siren. To test the alarm for function, put a volt meter
across the terminals where you removed the siren wires and activate the
alarm. You should get 12 volts or so. If you have voltage, then the siren
is bad.
Yes, any name brand 4 wire smoke will be fine.
Allan
THANKS AGAIN
I choose Polesoft Lockspam to fight spam, and you?
http://www.polesoft.com/refer.html
Thanks for the prompt response Allan, i have just tried what you said,
in fact the Panel Wire connection to the (Siren) says SPKR. I tried the
wires directly on the Battery and i hear no sound at all, no click, The
Speaker is possibly out of earshot but im pretty sure i would have
heard a click !! Im going to have to crawl up there and physically find
the Speaker and check it out before i go and buy a Voltage Tester. Ill
keep you posted !!
I sent my kid up in the attic and he retreived the Speaker(a Megaphone
Type Thing) after punching a large hole in the garage ceiling !!! now i
presume the Speaker is Bad because theres no response even when i
connect it direct to the battery
Robert L Bass
them directly across the battery. If the siren is good,
it will work. If it clicks, you have a speaker and not a siren.
If it makes one loud pop, you *had* a speaker. :^)
siren wires and activate the alarm.
Also, if you have a VOM (most voltmeters are VOMs), you can check
the wires leading to the speaker for resistance. If it's a
speaker or a combination of speakers it will usually show between
4 and 16 Ohms. Reverse polarity of the leads and you'll get the
same thing.
If it's a siren, you'll usually get a low resistance in one
direction and what looks like an open circuit or a very high
resistance when you reverse the poles.
siren is bad...
Yep, or the wire is broken.
Regards,
Robert L Bass
Bass Burglar Alarms
The Online DIY Store
http://www.BassBurglarAlarms.com
Stanley Barthfarkle
the battery. If the siren is good, it will work. If it clicks, you have
a speaker and not a siren. To test the alarm for function, put a volt
meter across the terminals where you removed the siren wires and activate
the alarm. You should get 12 volts or so. If you have voltage, then the
siren is bad.
Allan
That's a good way to trash a speaker.
OK Awesome, i have tested the Siren output connections with a Votage
Tester and it gives a 12v charge when tripped but no Sound at all,
absolutely nothing !! Ive banged it tapped it still nothing!! So it
must be the Siren gone Bad, Right ??????? Im gonna need a Drywall
installer next !!
Stanley Barthfarkle
12vdc self-driven sirens are cheap. check eBay.
After what seemed like 300 phone calls im going to pick up a Siren
later today, Are there no Home Alarm parts stores anywhere in Orlando
??? For just under $20. I hope its the right one though and i hope it
works,
Radio Shack dont have Alarm Siren Horns, neither do Home Depot, Lowes
or Ace Hardware, Radio Shack has some Security Stuff but its some Cheap
Chinese Stuff !!
Thanks again !!!!
Crash Gordon
Any response from your kid when he fell through the ceiling?
Crash Gordon
if he used a system battery probably yah.
have
activate
the
| > siren is bad.
| > Allan
Chub
with a speaker there is no response when it is hooked to a battery. so your
test proved you either have a good speaker, a bad speaker or a bad self
contained siren.
Robert L Bass
works,
I carry a wide array of sirens in my online store. We even
drop-ship some of them from a warehouse in Orlando.
Regards,
Robert L Bass
Bass Burglar Alarms
F
Frank Olson
You carry nothing in your "online store". It's a web based business.
How's the weather in Bahia, by the way??
We even
Translation: You "drop ship" everything and from the number of
complaints at the BBB, I'd say you're not very successful at that either.
