help with easy circuit thanks
Big House
Hello
I need a simple circuit, so I ask you the simpliest way to do it :)
All I need to do is this. I have a Vin of 9volts (battery), I need to
have a Vout=Vin for a few milliseconds (or even a few seconds is fine)
and then Vout=0. So the goal is: when you connect the battery Vout=Vin
for a few milliseconds/seconds (not important how long) and the Vout=0
I
Ian Stirling
Big House said:
Hello
A switch.
Slurp
Big House said:
Hello
Put a relay coil across your input with the NC contacts feeding the circuit.
Put battery across input, circuit gets full volts, relay energises and
disconnects circuit.
petrus bitbyter
Big House said:
Hello
These "simple" questions too often provide too little details to be
answered. From the question "as is" the answer will be "use a pushbutton, an
NO (normally open) type."
petrus bitbyter
Big House
well, it has to be it by itself without a switch... basically what I
need is an automatic swtich...
thanks
Big House
well, it has to do it by itself! basically I need an automatic
switch... Thanks
Genome
Big House said:
Hello
I am think you am need P-channel mosfet wiv RC thing on gate.
Also, get Gucci peeple to present things from other side of paper but don't
tell gearbox designers..... wink wink....#
DNA
petrus bitbyter
Big House said:
Hello
petrus bitbyter
John Fields
Hello
View in Courier:
+--[CAP]--+--O
| | | O--->Vout
[BATTERY] [COIL]- - -|
+---------+----------->GND
Cap is whatever it takes to keep the relay made (1000µF??) as long
as you want when the battery gets connected to the cap.
John Fields
Hello
View in Courier:
+--[CAP]--+--O
| | | O--->Vout
Oops...
+--[CAP]--+ O
| | | O--->Vout
petrus bitbyter
switch... Thanks
Well,
That's exactly my point. *When* do you need this temporary Vout=9V?
When the telephone rings? When the rain falls, or the nukes? When your
mother in law arrives or when she departs? Sometime something has to
activare that circuit but you did not mention anything in your
question.
petrus bitbyter
Jim Thompson
[snip]
[snip]
DNA
GRAMMAR ERROR! GRAMMAR ERROR! GRAMMAR ERROR!
It should be "wiv RC thingy", not "RC thing" ;-)
...Jim Thompson
Big House
would be too complex to explain, however let's say this.
- you plug the battery
- Vin=Vout for a short period of time
- after that, Vout=0 with Vin still connected.
That's it
Thank you very much!
Big House
Hello
what I need is simply this:
t=0, Vin=0, Vout=0
t=1, Vin=9, Vout=9
t=2, Vin=9, Vout=0
where t is in seconds (even though I do not need it precise, just a
chance of status in a "few moments") Thanks
Jim Thompson
Hello
t=0, Vin=0, Vout=0
t=1, Vin=9, Vout=9
t=2, Vin=9, Vout=0
When you connect the battery? As in a power-on-reset?
...Jim Thompson
Big House
when I physically put the wires on the battery... thanks
Spehro Pefhany
Hello
t=0, Vin=0, Vout=0
t=1, Vin=9, Vout=9
t=2, Vin=9, Vout=0
Are the changes in Vout driven by the input in the first case, and by
time in the second case?
Ie. wait for Vin to go high, then Vout = high for 1 second?
Best regards,
Spehro Pefhany
K
Ken Taylor
Use John's earlier capacitor and relay option. Easiest so far.....
Ken
Jamie
Big said:
Hello
you need a one shot timer.
look up 555 and one shot timer in google.
John Fields
maybe this'll make it even easier for him to visualize:
.. +------------+-------->Vin
.. +--[CAP]--+ O
.. | | | O--->Vout
.. [BATTERY] [COIL]- - -|
.. +---------+----------->GND
