help with homework
markben
Dec 27, 2016
4
hi
i need to find the current in the circuit number 48 it should be 0.6 amps.
can someone explain me how to solve it.
thanks.
Laplace
Apr 4, 2010
1,252
If you color-code the wires it should be easy to see that R1,R2,R3 are in parallel; R6,R7,R8 are in parallel; R4,R5 are in parallel.
markben
Dec 27, 2016
4
hi
i need your help. i need to find the total resistance in the circuit the answer is 0.5 ohm.each resistor is 1 ohm. but i don't understand how they connected. can you teach me how to recognize the type of connection if they connected in series or parallel connection.
thanks.
Laplace
Apr 4, 2010
1,252
Again, if you color-code the wires then it will be easy to see which resistors are shorted out.
markben
Dec 27, 2016
4
i really get stuck.
this is what i got.
after redrawing the circuit.
