Help with HV common emitter and push pull stage amplifier
Hello all,
I'm designing a high voltage amplifier and running into problems that
I'm sure that one of you might be able to guide me through.
Presently I have an operational amplifier (OPA37) driving a
common-emitter amplifier stage (NTE287) feeding into a push-pull stage
(NTE287 and NTE288) and then feeding back to the opamp.
Link to circuit diagram:
http://www1.pacific.edu/~nnjegova/Circuit.TIF
(disregard the split collector resistor it was there to allow for a
terminal that I could bootstrap to the input which by the way did not
help with gain)
I'll need the following specifications:
input: +/- 15V (from another opamp)
freq = (100Hz to 10kHz) possible > most signals will be near 1kHz
The output compliance must be at least +/- 180V (ideally +/- 200V take
a diode and current limiting resistor drop), and will be driving no
more than 1mA (typically 20uA) through 1M (that's right, MegaOhm) of
impedance.
My supply rails can reach +/-(200V to 500V) and source 3mA of current
out of each rail at maximum load
Right now I can input +/- 10 V (the output clips at anything above 10V)
at 1kHz and get an approx +/- 100V output. However I have thermal
instability with that gain (15 min and the output is distorted) and a
problem with attenuation at the other frequencies. I've tried a bypass
capacitor at the emitter in order to avoid thermal instability but when
I connect it I find that my output gets extremely distorted.
I've been trying different resistor values, especially with a higher
collector and lower emitter but I can't seem to get anymore gain out of
this circuit, just DC offset. I would like to just use bjts but I have
a couple of high voltage mosfets if needed. Also, I've been searching
this group and found the great diagrams that Dr. Hill posted for the
"basic high voltage mosfet dc amplifier" (by the way thanks for
authoring that great book) and I might go down that road if I cant get
my design working, but I was hoping that I could get an idea of why my
design won't give me the gain I was hoping for, as well as why it is
thermally unstable. I have the second edition of AoE if anyone wants to
reference it in their reply.
Thanks in advance and thanks for the discussions that you have all had
in the past about this topic.
Nik
Robert Baer
Hello all,
help with gain)
impedance.
Nik
1) You have too much attenuation of the DC signal from the output of the
opamp to the base of the inverter. Use a zener insead of a large value
resistor; the bypass is OK.
2) The gain of the inverter (about 130/12) seems to be less than the
feedback gain (1/14); that may cause a problem.
3) Check the over phase shift VS ferquency for possible compensation
corrections.
John Larkin
Hello all,
help with gain)
impedance.
Nik
I posted a circuit for a +-200 volt amp, made of one cheap opamp and
two high-voltage optocouplers. It's around here somewhere...
John
N
nikNjegovan
Yes, I've seen a couple of messages refering to it on ABSE. I must
apologise but I am new to the group and am not familiar with ABSE. Can
you explain?
Tim Wescott
you explain?
alt.binaries.schematics.electronic, if I have my spelling right.
N
nikNjegovan
thanks for the suggestions,
What about the DC offset that I get from changing the collector
resistor value? Does that occur because of a change in bias point? I
notice that I can increase gain but lose my center at the output.
Nik
W
Winfield Hill
Robert Baer wrote...
the opamp to the base of the inverter. Use a zener insead of a large
value resistor; the bypass is OK.
corrections.
Here's your faulty circuit:
.. +-------+--- +200
.. 123k |
.. R2 | |
.. ,-- 140k --, +--- pushpull out
.. in | | ,---||---, | emitter -----+---
.. -- 10k --+--|- \ | | | C follower |
.. | >---+-+- 480k -++-- B | |
.. ,- 10k --+--|+ / | E | |
.. | | A1 9k | | |
.. gnd | | 12k | |
.. | +-----+-------+--- -200 |
.. '-- 140k ---------------------------------------'
The first thing that's wrong with your circuit is the opamp error
amplifier A1, which should have infinite gain at DC to remove all
the offset voltages from the HV output stage. That means that R2
should be replaced by an integrating capacitor, plus a resistor in
series, adding a zero in the feedback to help stabilize the loop.
The second thing that's wrong is you've failed to add a respectable
level-shifting circuit to run the CE transistor Q1 at -200V. E.g.,
using a PNP common-base stage, Q2, like this:
.. 390k |
.. C2 | |
.. ,-||- R2 -, pnp level +--- pushpull out
.. in R1 | | shifter | emitter -----+---
.. -- 91k --+--|- \ | Q2 C follower |
.. | >--+- 68k --E C--+-- B Q1 | |
.. ,- 100k -+--|+ / B | E | |
.. | | A1 | 3.3k | | |
.. gnd | -15 | | | |
.. '-- 1.40M -----------------------------------------'
It's not clear that degenerating the Q1 stage gain is a good idea.
This circuit still lacks a decent output stabilization scheme, and
a class-AB output stage with defined-bias, plus foldback current
limiting, but it's a start.
F
Fred Bloggs
. +-------+--- +200
. 123k |
. R2 | |
. | | A1 9k | | |
. gnd | | 12k | |
. +-------+--- +200
. 390k |
. C2 | |
. gnd | -15 | | | |
I was favoring something more like this:
View in a fixed-width font such as Courier.
.. 200V
.. 510k 2.2M
.. +----|--PUSH -+---->
.. in R1 Q1 | | PULL |
.. -- 1.5M-----|+ \ Q2 | | |
.. | >--+-1k-E C--68k-+-- E C | |
.. +---||---+--|- / | B | B | |
.. | 47n | A1 | | 560 | | |
.. 100k | | gnd | +------+ |
.. | | C2 | | | |
.. | +-||- R2--+ +--|<|-|<|---+ |
.. gnd | | |
.. | -200V |
.. '-- 1.50M --------------------------------------+
W
Winfield Hill
Fred Bloggs wrote...
. 200V
. 510k 2.2M
. | | C2 | | | |
. gnd | | |
. | -200V |
The re-arrangement of A1 as a non-inverting amplifier is good.
The 68k between Q1 and Q2 isn't doing much; if you want to limit
the Q2 drive current to 3mA, you can raise its emitter resistor
to 3.3k, etc. The output stage would still have a very high gain.
I prefer to compensate the circuit with a capacitor from the
output to the Q1 input node, which (along with a series resistor
for a transfer-function zero) nicely controls the output-stage
gain, independent of other variables, and uses the local feedback
to lower its high-frequency Zout. The low-frequency part of the
stage gain is Xc/3.3k. A1's compensation network then becomes
easy, with an R2 zero to cancel A1's C2 pole just before the GBW
intersection. Then throwing away loop gain, as with the 100k and
47n, isn't necessary.
John Larkin
I like to add resistors to all-silicon-rail-to-rail paths wherever
practical. It keeps the shrapnel density down.
John
F
Fred Bloggs
The OP is using NTE equivalents of MPSA92 and MPSA42 in TO-92, so the
68k is there to limit Q2 power dissipation.
All good points.
W
Winfield Hill
the 68k is there to limit Q2 power dissipation.
It'll also reduce the Vce a bit, which is good. The A92 and A42 are
favorites of mine. They generally work well beyond their 300V max
rating, but the 400V rail-to-rail voltage presented is pushing one's
luck. If the O.P. only wants 150V out (G=15), then perhaps he can
regulate the supplies to +/-160V, which for a +/-150V range only
pushes the npn part to Vce = 310V at the upper output voltage limit.
This, or any further pushing, will dictate a more complicated cascode
circuit, such as we show in figure 6.52.
N
nikNjegovan
Thank you gentlemen. Your guidance is very much appreciated.
I too was concerned about the Vce of these transistors. I can regulate
the rails down but was wondering if anyone knew of popular BJTs that
can handle the rails. I do have some power MOSFETS (IXKC40N60C) from
IXYS that Have a Vdss of 600V. I was saving them for another project
but if they could be used in this design I would gladly put them here.
Any thoughts?
Dr. Hill,
Not sure what you mean by decent output stabilization scheme. I was
under the impression that the feedback loop to the opamp would take
care of any non-linearities in the output.
Thanks so much,
Nik
W
Winfield Hill
nikNjegovan wrote...
Any thoughts?
Dr. Hill,
I was under the impression that the feedback loop to the opamp
would take care of any non-linearities in the output.
Poles and zeros inside the feedback loop, Nik. Ahem! You never
heard of a feedback loop oscillating?
N
nikNjegovan
Ah, just making sure thats what you were mentioning and there wasn't
some clever trick of the trade that I was missing. Of course, I'll be
swapping capacitors all day. :) Thanks again.
Nik
W
Winfield Hill
wasn't some clever trick of the trade that I was missing. Of
course, I'll be swapping capacitors all day. :) Thanks again.
Clever tricks of the trade, yes, you betcha! We don't swap our
capacitors, we analyze and fit-to-order right the first time.
F
Fred Bloggs
You don't really have a lot of frequency space when the composite
amplifier BW is 100-10KHz. It seems that a pole zero pair on your main
CE stage has to roll off at -20dB/decade at 10KHz at the latest to hit
0dB by 1MHz, and that implies a maximum gain with local feedback around
the discrete amp of 40dB. One way to achieve that is an R+C pole-zero
feedback from the output to the CB transconductance level-shift amp for
40dB gain out to 10KHz, and then use a dominant pole on the main CE to
achieve 40dB at 10KHz. Then A1's R+C feedback to the IN(-) node is
selected to cutin at 10KHz and with an approximate 20x additive
superposition advantage to dominate the feedback phase from 100KHz
onwards. It has to be something like this if you want to keep the
performance flat over 100-10KHz. The THD comes in at 0.01% at 1KHz, so
that's a plus.
.. 200V
.. 10k 3.3k |
.. E E |
.. B-+-B |
.. Q2 C | C |
.. .---+-E C--------. | | | |
.. | | B | +--' |
.. OP37A | | | | | +-----PUSH --+->
.. in R1 22k | +---. | 4.7M | PULL |
.. -- 150k-----|+ \ | | | | | | | |
.. | >--+ - 22k | | +--||--+ | |
.. .--|- / | ^ | | | | 22p | | |
.. | A1 100k | | | | | C | |
.. | | +---+ | | +---- B Q1 | |
.. | | | | | | E | |
.. | 47p | gnd | | | | | |
.. +---||----' | | C | | |
.. | === +-- B Q3 v | |
.. | |680p | E - | |
.. | | 3.3k | | | |
.. | 2.2M +----+------+------' |
.. | | -200V |
..gnd--150k--+---2.2M--------------+-------------------------------+
Rich Grise
And since google groups doesn't carry binaries, either someone will
have to be kind enough to slap it up on a website somewhere and post
a link, or nikNjegovan will have to get a real newsserver. )-;
Rich
