mas
- Jan 1, 1970
- 0
Hi all
I'm looking to control some devices from my computer. I've decided to
play around with the parallel port.
I've gotten this advice from somebody.
Output multiplexer for parallel port:
http://homepages.slingshot.co.nz/~peg/parport128.GIF
Initial condition, C0 and C1 high
1 put address of 373 on data bus (0 to 15)
2 toggle C1
3 put 373 data on bus
4 toggle C0
Three of these could be driven from one port by using C2 and C3 instead
of C0
To drive your loads use (logic level mosfet)s (google) You will get
hits like:
http://www.nteinc.com/Web_pgs/LL_MOSFET.html
I've very intersted in doing this, as I'm looking to control 100+
devices. For starters I'm just looking to switch some LED's on and off
after the 373's. I'm not sure what mosfets to use and how exactly to
tie them into the diagram mentioned above. In the end I'm wanting to
switch 1 amp.
Eventually I'm going to also want to add in a continuity check (LED
that operates on less than 50 milli amps) on each of the connections to
the switching device after the 373. I'm probably going to be placing
some sort of terminal block in there for easy connection.
Any advice is appreciated.
2 toggle C1
4 toggle C0
of C0
hits like:
switch 1 amp.
