Help with Mosfet data sheet.
chapmjw
Can one of you EE's please help an ME understand the details of a
mosfet data sheet. The values I've calculated are not even close to
real world results. My understanding of the data sheet is limited to
what I have read on this and other news groups.
Here's what I've done thus far.
To test my calculated values to a real world example I did the
following.
24V dc precision power supply
1 mosfet STP1920-NB (TO-220 case)
1 Heating Element reads 13.xx ohms
With this connected and powered up, I get a current reading of 1.540
amps.
From the data sheet I get the following info.
RDS(on) .15 ohm
Tja 62.5 C/W
From search results online I used the following to predict the rise in
temp on the case.
Ambient Temp 27.8 C
Power dissipation (1.54 * 1.54) * .15 = .35574 W
Rise in temp = Tja * PowerDissipation
62.5 * .35574 = 22.23 C
Case temp = ambient + RiseInTemp
27.8 + 22.23 = 50.01 C
In about 10 seconds time the actual value I'm reading on the case is
almost triple that at 148 C .
Data sheet for the mosfet is here:
http://rocky.digikey.com/WebLib/ST Micro/Web Data/
STB19NB20-1,%20STP19NB20_FP.pdf
Any help is greatly appreciated
Jim
F
Fred Bartoli
following.
amps.
RDS(on) .15 ohm
Tja 62.5 C/W
temp on the case.
Ambient Temp 27.8 C
Several points:
1) 24V/13.xx = 1.84A and you measure 1.54A This seems to indicate your
mosfet isn't saturated. How much gate drive do you have? You can check
the source-drain voltage which should be under half a volt.
2) Apart this your calc is almost OK, except the you forgot to correct
RDSon for temperature (see curve GC74110 page 5).
linnix
That's why you always need to test the theory.
following.
amps.>From the data sheet I get the following info.
If your supply is stable at 24V, the resistance across the MOSFET is 2
ohm, not .15 ohm. R(mosfet) = V / I - R(ele)
RDS(on) .15 ohm
Tja 62.5 C/W
temp on the case.
Ambient Temp 27.8 C
With 2 ohms, the junction temperature would be close to 300 C.
Sound right, with the temperature gradient.
Data sheet for the mosfet is here:http://rocky.digikey.com/WebLib/ST Micro/Web Data/
Jim
You can't just drive this with a constantly on MOSFET.
Ban
following.
amps.
RDS(on) .15 ohm
Tja 62.5 C/W
temp on the case.
Ambient Temp 27.8 C
Jim
The real world is more like this:
24V supply
-0.15V meter loss
-(14R*1.54A) Heater has pos tempco
= 2.29V across FET *1.54A = 3.5W
Why does your fet have almost 1.5R ?
Your gate voltage is too low, or you have made up a wrong circuit. Your fet
must have the Source on gnd, and the load is between +24V and Drain.
Joerg
I would agree. Even if 13.xx would be 13.99 ohms that should result in
about 1.7A, provided the 24V are really precise. Either the FET
gate-source voltage isn't high enough or maybe gate and source are
reversed and Jim is accidentally running it via its body diode, which is
slowly frying the thing up.
Without a heat sink it's probably just a few seconds until smoke signals
will emerge and some bits and pieces fly off ;-)
Why not? A FET with an Rdson of 0.15ohms looks alright here. If it's fed
the proper gate voltage, that is.
