FlexedCookie
- Oct 2, 2014
- 11
- Joined
- Oct 2, 2014
- Messages
- 11
Hi guys,
Needing some help in getting my MOSFET switch circuit to work.
Currently im using IRFZ34NPBF power mosfet, and im trying to use it to switch a DC motor on and off with PWM from an arduino.
My current circuit is attached below.
At the moment, I've got it wired up as shown, and am just trying to control the gate voltage with a power supply outputting 3V DC.
My problem is that whenever I do this, the mosfet never turns on. I checked the voltage between the resistors and the gate, and it seems like there is no voltage going to the gate of the mosfet.
Also interestingly, i can take out the wire leading to the gate from the resistors, and then just put a resistor from the gate of the mosfet to ground, and all of a sudden the motor works. However, i can do this nonstop until i turn off the power supply, which makes me think the mosfet isnt turning off.
