[email protected]
- Jan 1, 1970
- 0
I have an ADC which takes an input signal in the range of +/- 64mV
relative to ground. I am using this to read a thermocouple for
measuring exhaust gas temperature, and it works fine if I use a probe
with an ungrounded hot junction; I tie one side of the cold junction to
ground at the ADC and measure the other side. In order to use a more
common grounded probe, which is my goal, I need a differential stage
before the ADC.
The +/- 64mV range is just about right for my purposes, so I do not
want any gain, nor do I want to switch ADCs if I can help it. If it
simplifies the analog stage I can deal with a 0-64mV input and output
range ( i.e. I do not need to measure probe temperatures below the
"cold" junction temp, although it wouldn't be undesirable to be able to
do so.) I do need to reliably read values very near 0 volts.
I understand how to use an opamp to convert the difference in voltage
between the two halves of the cold junction to a ground-referenced
voltage. I am having trouble selecting the correct opamp. I want to
minimize errors due to offset voltage or nonlinearity, but if possible
I don't want to spend $8/ea for the parts.
I am using a single +5v supply.
Any advice will be appreciated.
before the ADC.
