help with panasonic 32" geometry
Porkviolence
am i able to fix the vertical geometry while in the service mode? I am
able to access service mode but do no know which codes would need to be
adjusted. There is a menu A, B, C, P, S, and X. Any help would be great.
Thank you
Jason
Panasonic CT-32G6E - 2001
You have vertical size and centering available in the service mode on
that ultra low end model in Panasonics line.
If the vertical geometry is actually off, then the vertical circuit
needs repaired, probably failing capacitors.
Porkviolence
do you happen to know what settings need to be alters to fize the vertacal
size?
