Help with PSPICE digital simulation
Patrick
hello everyone,
i'm trying to simulate flip-flop circuits using nand gates only
(cross-coupled nand gates) for a school project with PSPICE. however
the outputs of my nand gates ( Q and Qnot ) always seem to be at the
"don't care" (or "X") state after i run the simulation. is this
because the simulator doesn't know what are the initial states of Q
and Qnot. is there a way around this? any help is appreciated. thank
you.
patrick antoun
Jim Thompson
hello everyone,
you.
patrick antoun
Digital Setup, Flip-Flop Initialization
...Jim Thompson
Patrick
thanks, will this work (digital setup) even though i'm not actually
using any flip-flops (my circuit has only cross-coupled nand gates)?
If so, where do i find this digital setup?
patrick
Patrick
i forgot to mention that i'm using pspice from Orcad version 9.2.3 (Cadence).
thanks again,
patrick
Jim Thompson
patrick
[snip]
Analysis Setup
You could also try a .IC=0 (initial condition) on one of the NAND
outputs.
...Jim Thompson
Charles Edmondson
patrick
[snip]
Analysis Setup
outputs.
...Jim Thompson
Patrick,
Take a look at your design. What is setting the state at start-up?
Your design SHOULD include signal or circuitry to set that initial state
at the beginning. Even if you have a few digital sources that go from 0
or 1 to Z (high impedance) just to kick things off...
Jim Thompson
patrick
[snip]
Analysis Setup
outputs.
...Jim Thompson
Patrick,
Hmmmm?
Charlie,
Am I learning a NEW trick? Can part "DigStim" do that, 0 -> Z? Or
what part should I use?
...Jim Thompson
Charles Edmondson
Jim said:
Jim said:
On 13 Mar 2005 09:16:05 -0800, [email protected] (Patrick)
patrick
[snip]
Analysis Setup
outputs.
...Jim Thompson
Patrick,
Hmmmm?
Charlie,
...Jim Thompson
Wellll.... you could, but that invokes the stimulus editor.
I would use a stim1 part. That lets you give it a series of commands in
time state format.
0s 0
1us 1
2us Z
is one such command sequence. The other stim parts let you have buss
stimulus defined.
Jim Thompson
patrick
[snip]
Analysis Setup
outputs.
...Jim Thompson
Patrick,
Hmmmm?
Charlie,
...Jim Thompson
time state format.
0s 0
1us 1
2us Z
stimulus defined.
I called it by the wrong name. That will be VERY useful... THANKS!
...Jim Thompson
Patrick
Patrick,
Charlie,
Since i'm new to digital simulation using PSPICE 9.2.X i guess i don't
have anything that sets the state of the outputs (Q and Qnot) of the
cross-coupled nand gates. if i was actually writing the netlist i
would include a .IC or .NODESET command. but since Capture is all GUI
i don't know how to include this kind of initial condition in my
circuit.
i tried connecting a 10k pull-up resistor for the output of one nand
gate (Q) to VCC. this seemed to sort of work, but it makes the circuit
analog/digital (by introducing analog components) and the square wave
at the output of the flip-flop wasn't as nice looking and the clock
source. there must be a way to accomplish this without having to use a
pull-up resistor.
ultimately i'm trying to simulate a clocked JK flip-flop (with preset
and reset asynchronous inputs) using 2-input and 3-input nand gates.
this is for a school project. i greatly appreciate and help with this
problem. thanks again.
Patrick
Jim Thompson
Charlie,
circuit.
pull-up resistor.
Patrick
Charlie told us how...
"I would use a stim1 part. That lets you give it a series of commands
in time state format"
(Use part named "STIM1")
0s 0
1us Z
Tie to one Q of the cross-coupled NANDs.
...Jim Thompson
Charles Edmondson
Jim said:
Jim said:
On Mon, 14 Mar 2005 10:14:49 -0800, Charles Edmondson
patrick
[snip]
Analysis Setup
outputs.
...Jim Thompson
Patrick,
Charlie
Hmmmm?
Charlie,
...Jim Thompson
time state format.
0s 0
1us 1
2us Z
stimulus defined.
...Jim Thompson
No Problem!
Just remember that this uses the standard stim set up in digio.lib, so
it is typically 0-5v, and goes up to about 2Ghz reliably.
Also, the Z is what is set up in your digital options, so if you need a
really high Z (the default IIRC is only 10K) you need to change your
options.
Charles Edmondson
0s 0
1us Z
...Jim Thompson
And, depending on your set up, you might need the complement on the
other one. Remember, if you get an indeterminate signal in your setup,
it can propogate throughout your circuit...
Jim Thompson
Jim Thompson wrote: [snip]
...Jim Thompson
No Problem!
options.
Hi Charlie,
Looks like the library is actually named "dig_io.lib" ;-)
I find "Z" is 1Meg in most logic families, but 200K in TTL.
I couldn't find "Z" defined in relationship to "STIM1"
Where is that set?
...Jim Thompson
Charles Edmondson
Jim said:
Jim Thompson wrote:
[snip]
...Jim Thompson
No Problem!
options.
Hi Charlie,
Where is that set?
...Jim Thompson
In your sim options, it is called DIGDRVZ, and on my version defaults to 20K
Usually an advanced digital option.
Jim Thompson
Jim said:
Jim Thompson wrote:
[snip]
...Jim Thompson
No Problem!
options.
Hi Charlie,
Where is that set?
...Jim Thompson
Is that available readily to those of us still following the true
faith (AKA MicroSim PSpice Schematics) ?:)
Aha! Found it right there in the plain vanilla Options settings.
Is there a way to set Options to always be the values I want, and to
always appear as the defaults?
...Jim Thompson
Charlie
...Jim Thompson
Hi Jim,
Not really. You can always create a .inc file with the options set the way
you want.
Or wait, can you set them in the pspice.ini file? No, I guess not. In
Capture, you can now import a standard simulation profile... :cool:
Charlie
Jim Thompson
Hi Jim,
you want.
Charlie
Or get a substitute with a MicroSim-Schematics-like front-end...
<http://www.trabucotechnologies.com/> ;-)
But I guess you are right... just do a .INC*
Any advantage of .INC* versus .LIB*
...Jim Thompson
Charles Edmondson
...Jim Thompson
Include files add all the lines into the netlist. A library only adds
called models, so use includes for setting options and adding 'stuff'!
