Help with Sears Mower 917.387440
spongehead
I picked up this Sears model 917.387440 6.25hp push lawnmower at a yard
sale for 5 bucks and someone had attempted to do some carb work on it
which failed miserably by looking at it. The gas line is cracked and
the jet needle was missing. Easy enough to get those parts at the
local Sears place. However, I cant really tell how the carb levers and
springs go into place, maybe Im missing another part but hard to tell.
I was hoping someone might have access to or know where I can get a
real picture of how it looks put together.
Sears engine model is 143.006200
N
none
It's most likely a Techumseh engine on it correct?
Is it set up for throttle free runningor does the mower have a
throttle control?
I repair these things all the time and can set you on the correct
course to having that mower running in short order.
The gas line is 1/4 inch, just go down to a auto parts store and buy a
foot of it and cut to length.
There is no jet needle, I'm assuming you're talking about the fuel
supply needle that goes on the float?
You'll have to purchase that as part of a float kit if you go through
sears. It can be had separately at most lawnmower supply shops.(You
should get a seal o-ring as part of the packet as well. It's the
o-ring that goes up in the needle well. white rubber about 1-2 mm's in
dia.)
The float will be plastic and 90% of the time is fine. Check to see
if it has leaks to be on the safe side, or you'll get gas flooding
problems.(tie a weight on it and submerge in water if you get bubbles
it will need replacing as well. once removed from the water take a
look at it as see if it's got any water inside, just give it a shake.)
The govenor spring and link are easy. On the side of the engine casing
you'll see the governor control arm(shiny metal with two holes in the
top end.), the top hole is for the bent angled wire control link. It
goes to the back hole on the carbuerator butterfly, under the govenor
assembley plate. The spring with the short straigt wire link will go
to the lower hole and to the throttle control arm that sticks out from
the throttle plate assembley.
The diagrahms on the sears site won't be detailed enough for you to
see this. I'll either have to talk you through or send you some
scans/vidcaps.
Talk to me if you can't find someone locally and I'll snap those pics
for you monday.(I have several Techumseh's engines in shop)
spongehead
Yeah it is a Techumseh but the float is metal and seems to be in good
working order. I am able to get a rebuld kit at Sears for about 15
bucks, includes gaskets and the fuel supply needle. That should get it
going hopefully.
Just you describing which wire link goes to which hole, I think I got
the jist of it.
Is there ever problems on the inside of the motor where the governor
control arm is? I just havnt worked on a motor like this, usually the
basic briggs stuff.
Thanks for all the info!
N
none
going hopefully.
the jist of it.
basic briggs stuff.
Nah, usually no problem. Though it does depend on the stupidity
quotient of the original owner.
And yeah your right, it's a metal float. My memory gets lousy at my
age plus I'd spent the last few days working on Briggs and honda
motors so plastic got stuck in my mind.
Techumseh's as of the past decade or so have gotten to be the most
reliable motors out there.
Don't get too over confident about those links, it's easy to get the
wire link on backwards and they do have to go on exactly right.
Like I said I can send you some vid caps or stills of just how they go
on if you need it.
You can make the flat intake gasket yourself with some fibre gasket
sheets and an exacto, the float bowl gasket usually lasts for a long
time.
The needle can be got solo at most small engine parts/lawnmower parts
shops.
A hint, Sears uses the same parts numbers as the oem's so you can use
the sears # at the lower cost parts houses.
There are tons of places online as well.
http://www.docsysllc.com/main.htm
http://www.jackssmallengines.com/carb_t.cfm
http://www.m-and-d.com/
http://www.westernauto1.com/engines/Tecumseh/tair.html
http://www.smallengines.cc/
Just a few.
seems to me the last time I actually bought a new needle I got it for
around 6 bucks with the seat o-ring seal included.
spongehead
Not bad, was able to find it for 11 bucks. If you want to send pic of
linkage, just add "msp" after the underscore.
I did notice the spring was all stretched out, not sure how important
that is or if I can get away with stretching it some more.
Sam Goldwasser
Probably:
http://www.angelfire.com/mb2/visitme/mower/tecumseh.html
The spring is probably fine, that's the way it is.
--- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
+Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
| Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
Note: These links are hopefully temporary until we can sort out the excessive
traffic on Repairfaq.org.
Important: Anything sent to the email address in the message header above is
ignored unless my full name is included in the subject line. Or, you can
contact me via the Feedback Form in the FAQs.
spongehead
Theres the pic I was looking for. Thats perfect, thats a bunch.
N
none
Probably:
If you follow the diagrahms at that link you'll be installing the
govenor spring link BACKWARDS.
The short wire section of the link goes into the lower hole on the
govenor control arm not the spring.
Insert the wire through the front of the hole and the spring goes onto
the throttle link arm on the throttle plate assembly.
N
none
If the spring is stretched replace it. Proper tension and spring
length is importnt for proper govenor function as well as smooth
throttle control.
spongehead
Oy. So just reverse the smaller link wire and spring. Ok, I'll give
it a try. Its going to be a week or so before I get the carb kit,
would another fuel supply needle work as long as it fits in the hole
and the float?
N
none
and the float?
It needs to be the exact needle. Virtually all techumseh carbs use the
same size needle/float.
If the spring link is working in reverse go ahead and leave it that
way.( to much handling can stretch it and that's bad.)
I'd recommend looking around for a source for second hand parts.
I get mine from toss offs, you'd be amazed how many people just toss a
mower because it simply won't start on the first pull or so when they
drag it out in the spring.
Try asking at your local small engine reapir shop for that needle,
they might sell you one for next to nothing.
If all else fails give me your address and I can send you one cod on
the postage.(I still have a few in my parts bins.
spongehead
I got the needle at a local repair guy for 2 bucks. Came with needle,
clip and some liitle white gasket looking thing. The white thing didnt
quite fit anywhere so I left it out. Put everything together and it
started right up but didnt last long. I have to keep pushing the bulb
to keep it going. Is it because of the little white thing or am I
losing air somewhere?
James Sweet
Is this an engine with a float bowl carb? If so, remove the banjo bolt that
holds the bowl on and clean out the tiny passages in it, those clog easily.
Sam Goldwasser
Functionally, they are equivalent. The only issue is whether parts
interfere. There have been all sorts of arrangements depending on model.
The important thing is that the solid wire goes between the governer lever
and throttle plate on the carb. The spring'd wire goes between the governor
lever and throttle control (or fixed location if non-adjustable).
And, yes, which hole in the governer lever are used for each matter!
spongehead
After a closer look in the carb, I realized that the old rubber tiny
gasket thing was still seated. D'oh! I also noticed some guck in the
little holes of the float bowl cover screw. After getting everything
straightened out, it runs fine. Some minor spring adjustments and the
lawn is mowed.
Thanks to all!
N
none
The little white o-ring is the needle seal. It goes up in the needle
well.
If you look up in the needle well wth a flashlight you'll see the old
seal.(It'll be stained a yellow-brown color from the gas.)
Yo can pry it out with a small right angle dental pick or a slotted
jeweler's screwdriver. alternately you can also get it out by shooting
compressed air through the fuel supply inlet, should pop right out.
Press the new seal in using a dowel or punch the same diameter as the
seal. A bit of fine machine oil can be used to lubricate it to make it
slide in easier.. Be sure it seats firmly in place.
Test the needle to seat action before reassembling the carb to avoid
flooding out the mower.
You say it didn't last long. Did it just quit after running for awhile
or did it try to start and then die out?
The next thing that could be a problem is the primer bulb.
Depending on the model it could either of three different type priner
bulbs.(The carbuerator draws part of the suction required to pull gas
from the bowl through the primer bulb ports. If the bulb is rotten or
has a puncture it'll cause suction loss.)
A visual inspection on the bulb will usually tell. It'll be cracked or
split or be "gummy" when you squeeze it.
It's easy to replace and doesn't cost but 3-4 bucks.(Sears or parts
store.)
It'll be either the round non vented bulb, black, red or orange in
color or the accordian style that comes in either non-vented or
vented.( will have a small 1-2mm hole in the center of the bulb.)
All are held in by a circular spring clip. It has 5 or so square tabs
that stick out to grab the primer bulb well walls.
It can be prized out using a small slotted blade screwdriver, either a
#0 ot a narrow slot #1 blade.(jeweler's driver will work as well.)
Spray the whole spring and housing with a bit spray oil to slick it up
a bit.
Prize under one of the tabs until it moves out a bit then mover onto
the next one going a bit at a time in a circular pattern until you get
it out completely. The bulb can then be pulled or prized out. don't
worry about damaging it, it's a toss off item and can't be fixed.
Clean out the well with a bit of carb cleaner spray and a stiff
bristle brush, wire bruch is fine. You can also scrape out the old
rubber with a screwdriver or dental pick.
To install the new bulb just place the bulb all the way in and press
in the new retainer clip with a small slotted screwdriver.
This is done by placing the tip of the screwdriver into the circular
depression in the ring and pressing a gently at different points of
the ring in a circular pattern untill the ring is all the way against
the lip of the primer bulb. Then gently but firmly press with the
screwdriver in the depression of the ring at the base of each of the
retaining tabs.
You can test for a firm seat and lock by simply pinching the tip of
the primer bulb between forefinger and thumb and giving it a gentle
tug.
If it pulls out the tabs on the retaining ring have been overstressed
and need to be bent out straight.(Sometimes they come from the factory
out of spec and won't form a tight fit on your particular carb
housing.)
If the original ring came out in one piece and didn't snap you canuse
that one.
However to retension a spring, new or old, you use a pair of needle
nose pliers and gently bend the tabs out a bit so that they'll fit
snugly down the bullb well on your carb. Just be careful as it is easy
to snap the ring itself overstressing the tabs.
Also ensure that all of the fine ports on the carb are clean. This
includes the small hole on the lower side of the primary jet well.(The
well that the brass jet/bowl screw screws into.)
Also the brass bowl retaining screw depending on the model also has
one or two small ports on it that need to be clean for fuel to get to
the main supply port.
The short screw has one, the taller screws have two, 180 degrees
opposed at the base of the screw.(just under the hex head.)
You can use an aerosol carb spray to clean them out. I use either the
High-Tech brand from Wal-Mart, The store brand from Autozone or a good
name brand like Justice Brothers Carb spray. Anything that is acetone
base is good. Avoid Gumout carb spray, worst stuff made.
Most all come with a red plastic pipette for blasting out fine ports,
use it.
If the clog is stubborn spray some cleaner in a small cup and soak the
parts to soften the clog up.(I use the plastic cap that comes on the
spray can.)
If the ports won't unclog using the cleaner take a small piece of
stiff wire.( I use a piece of copper strand from a piece stranded
automotive wiring 18 gauge or whatever.)
Gently push it through the clogged port to break up the tarred gunk,
follow with a healthy spray of cleaner.
Use the pipette and carb spray to back blow the ports in the main
intake of the carb also. This'll clean out the primary suction port
that runs through the welsh plug and the seconday that runs through
the primer bulb housing.
Let parts dry or blow off with compressed air, then reassemble carb.
N
none
It's the bulb, gone bad. Easy to replace. See my reply to the other
posts on this subject.
Will be glad to assist with more details and if needed pics.
