Brad Velander
- Jan 1, 1970
- 0
Rob,
there are several possibilities and it sounds like you have a
good idea what they could be but haven't had any luck yet.
For a comment (I assume that you are not displaying them) use
the global edit function combined with the position ("center") to
bring them all to the center of the components. Possibly make all
comments visible with a global edit first.
A designator could be done similarly but then you have to
re-arrange all your other designators afterward. Not so good but
if you have to, you have to. Also make sure that all designators
are visible with a global edit.
Another common one outside the board area is a polygon that
was moved without knowing it, like when it was not deselected and
you moved something else. This is doubly troubling when the
polygon may have the remove dead copper turned on. If it is
outside a valid net connection then the whole polygon disappears
after pouring.
Is there any possibility it is a component primitive? Did you
ever unlock component "primitives" (not the lock component)? That
can be tough as well because you may not know which component it
may belong to.
There are various selection problems with items outside your
board or in the negative quadrant areas. Not all selection
methods work, one that worked with one item may not work with
another item.
You seem to have tried using the select outside area, I have
typically not found it to work with your type of problem.
Try this, use select all (S,A) move the board and all other
items in a direction that should bring the errant item into view.
Watch the bounding box around your selection as you move it to
give you hints on which direction and how much to move. If you
bring the item into positive quadrant space then you can easily
deal with it.
If the previous methods don't prove useful try, select all
(S,A), the use deselect inside (E, E, I) and draw a bounding box
around your proper board area, be generous allow an inch or two
at least around your board or other desired items. Once the
proper board area is deselected then delete selected (Shift and
Delete).
Hopefully one of those works. As a last resort you could try
saving the file in ASCII format and edit it with some text editor
to try and find the offending object. Edit it's coordinates to
bring back to the positive quadrant at a known location.
after pouring.
may belong to.
another item.
deal with it.
Delete).
