High Bandwidth Digital Pot
Hi. ANyone knows about a digitally controlable potentiometer that has
a wide bandwidth. It's for a portable-scope project so I would need a
bandwidth something like 20MHz minimum. Do anyone knows if its a good
idea to use the digital pot in the feedback loop of a inverting-amp
(op-amp).
Will my signal still be clean.
Well thanks
V
Vladimir Vassilevsky
a wide bandwidth.
Take a common 100 Ohm potentiometer and attach a step motor to it.
(op-amp).
Bad idea. Digital pot is RC-RC-RC-RC.... Stability and response will be
problematic and varying with gain.
Well thanks
The design of the scope front end amps is not trivial and requires a
great deal of experience.
DSP and Mixed Signal Design Consultant
http://www.abvolt.com
Glenn Gundlach
(op-amp).
Well thanks
Maybe these guys have something you could use.
http://www.analog.com/en/subCat/0,2879,759%5F787%5F0%5F%5F0%5F,00.html
I used the AD603 10 years ago and it did everything AD said it would
GG
http://www.analog.com/en/subCat/0,2879,759%5F787%5F0%5F%5F0%2...
GG
These pieces seem quite interesting. But since it's a portable scope,
I only use 3.3v powered devices and many of this amps require 5 or
12v. So I'm thinking about an analog multiplexer that could handle
wide bandwidths and a set of non-ajustable amps. Still, if someone has
another idea please tell me.
Joey Caron
Paul Hovnanian P.E.
(op-amp).
Well thanks
Use a programmable gain broadband amplifier.
