High Current Low Voltage Power Source
V
vijayamurugan.P
hai Designers
this is vijayamurugan from VIT^,Velore,India
I am a P.G Student.
i have to design a D.C low voltage high Current Power Source
[Convetrer]
Ratings are
1800 Amps,75 Volts.
So i kindly request you the designers to suggest me a better Converter
Topology,Devices suitable for such ratings.and related things
Thanks in Advance
bai
vijay<[email protected]>
___________________________________________________________________
VIT^ - Vellore INstitute of Technology,Vellore,Tamilnadu,India. and is
evergrowing. http:\\www.vit.ac.in
martin griffith
hai Designers
I am a P.G Student.
[Convetrer]
Ratings are
1800 Amps,75 Volts.
Thanks in Advance
bai
There is not enough information in your post
1800 Amps,75 Volts.
the input or output specification?
martin
Serious error.
All shortcuts have disappeared.
Screen. Mind. Both are blank.
V
vijayamurugan.P
that is the output requirment
not input
suggest
F
Fred Bartoli
not input
suggest
1800A 75V output, no input.
Hmmm, let me think...
Yes... I'd go for an alternator feeding an AC motor that will drive the
alternator.
Mook Johnson
I think what he was getting at is:
What is the input power source that will supply your converter?
This is a 135K Watt output so you will need a special supply to provide
enough input power for such a beast.
Typical AC wall plug won't get it (typical 1.8k Watt)
Is this a sustained output or a pulse? If pulse how wide?
V
vijayamurugan.P
sorry sir
the input is 3 Phase AC 415V 50Hz/60Hz
the output Requirment is 1800 Amps,75 Volts.
Suggest me suitable Converter confihuration & devices used in the
circuit
Rene Tschaggelar
hai Designers
I am a P.G Student.
[Convetrer]
Ratings are
1800 Amps,75 Volts.
Without much experience at that power level, I'd
have a look at synchroneous rectification with a
FET recifier. Before that some multiphase
PWM modulators and a truckload of ferrite transformers.
Alternatively, thyristors in a 6 or 12 pulse
arrangement might be a solution.
Either way, a wrong trigger is going to be costly.
Don't even think of the sweat required to change
all parts.
Rene
W
Winfield Hill
vijayamurugan.P wrote...
in the circuit
To design (or even just to specify and purchase) a 135kW
power converter, you need to hire an experienced expert.
John Woodgate
I read in sci.electronics.design that Fred Bartoli <fred._canxxxel_this_
bartoli@RemoveThatAlso_free.fr_AndThisToo> wrote (in <4152b7d8$0$32712$6
[email protected]>) about 'High Current Low Voltage Power Source', on
Thu, 23 Sep 2004:
alternator.
He says 'not input', not 'no input'. But a rotating machine solution
seems to be a reasonable one for those numbers. Certainly much quicker
to develop!
Charles Elliot
dated 23 Sep 2004 04:39:36 -0700,
that is the output requirment 1800 Amps,75 Volts.
not input
What is the input ?
John Smith
sorry sir
circuit
1. Step down transformer
2. High current diodes (http://www.nteinc.com/Web_pgs/Industrial3.html)
3. Heat sinks for item 2
If you want smoothed DC, add items 4 and 5:
4. Filter inductor
5. Filter capacitors
Wire diodes in a full-wave bridge configuration
Guy Macon
This will require very expensive parts.
Hire a high-current power supply design expert
- your total system cost will be lower.
F
Fred Bartoli
Thu, 23 Sep 2004:
Yes. I noticed that but I couldn't help it and expected nobody would jump on
me.
....but I forgot about you :)
to develop!
Sure.
legg
sorry sir
circuit
At this power level, the requirements of the load will play a
significant role in determining the conversion method. Of major
concern are weight, volume, and regulation/ripple expectations. Cost
and environmental factors may also limit your choices.
If this is a tech school project, then you should identify one
practical application and concentrate on satisfying this one
application, as part of the design process. This will allow you to
make practical decisions about, for example, whether DC is actually
preferable over AC, as niether is intrinsically stated in your spec,
so far.
Once identified, you may find that the 75V and 1800A are not actually
required simultaneously - that the system power level is lower than
the label requirements suggest at first glance.
If you google for "MEGAWATT SOLID-STATE ELECTRONICS", you'll find a
number of informative articles, that may help in determining your
approach to a full-powered system.
RL
Clarence
hai Designers
I am a P.G Student.
[Convetrer]
Ratings are
1800 Amps,75 Volts.
Thanks in Advance
bai
So what are you going to do with a Superconducting magnet supply?
Build a collider?
WMD's maybe?
Or just trying to get the design for a $25,000 supply free?
V
vijayamurugan.P
This Power Supply is Meant for Magnetising Application.
magnet making materials are powdered and kept in a thin cylinder.
by applying a huge magnetic field we align the particles and
Compressing will give u asolid Magnet[permanent magnet]
the role oh such a high power source is to maintain the magnetic Field
whil magnet is made
thank u all for a live Dicussion
-vijay
W
Winfield Hill
... the role .. is to maintain the magnetic Field while
magnet is made.
That's another matter, a short peak-current, much easier.
Big capacitors, SCRs. How long do you need it to last?
How big are your magnets? Tell us about your coils.
Rich Grise
Would this be somewhat like a coin squeezer, but more like
a core sinterer? :)
Rich
W
Winfield Hill
Rich Grise wrote...
a core sinterer? :)
Burt's quarter shrinker uses ~ 20kV and 100,000A for a few
microseconds, I suppose a big magnet energizer might need
2kV and 5000A for a few milliseconds? A capacitor bank and
an SCR, or two...
Pooh Bear
whil magnet is made
That just needs a pulse - not continuous DC. Somewhat simpler !
What pulse width is required ? Repetition rate ?
Graham
