High speed ADC with USB interface
Guest
I'm looking for 12-16bit ADC with 4MHz samplingrate capable of storing 4K
samples, with USB interface to transfer data to a PC.
Any recommendation ?
U
Ulf Samuelsson
I doubt that you will find this ADC/USB/Storage on a single chip.
With 4 Mhz sample rate and 12 ´bit resolution
you need 48 MHz operation for a serial interface
so it is likely you need a parallell interface.
I assume you store the samples first and then send it over USB.
Then you need 8 kB of storage for the samples.
Is it acceptable to use a UART at 115 kbps which connects to a USB-Serial
bridge?
You can transfer 4kW in about 1 second?
You would be looking for a micro with
* DMA capability for 4 Mtransfer/s
* 16 bit Bus
* 8 kB extra SRAM (16 kB min)
* USB interface, or connection to an external UART-USB bridge
* External ADC
The AT94K05 FPSLIC has enough RAM and can directly interface to
the ADC using the FPGA area, but lacks the USB.
Richard Webb
Analog Devices do some evaluation boards for some of their ADCs which you
can interface to their 'USB FIFO' board, might be suitable, although I think
the ADCs in question are far faster than 4MSPS.
Mike
WoW now that would be something for sure - geeeesh as I ponder
the frailties of using a 60KVA 3-phase UPS as a paperweight !
Guest
My appologies.!.. Altough I said ADC, what actually I mean an ADC board, not
necessary single chip.
My corrected question is;
I'm looking for 12-16bit ADC Board with 4MHz sampling rate capable of
storing 4K samples, with USB interface to transfer data to a PC.
Antti Keskinen
not necessary single chip.
A 12-16 bit ADC with 4 Mhz sampling rate requires a minimum throughput of 48
Mb/s, and a maximum of 64 Mb/s. This means you must have a Hi-Speed USB 2.0
IC, which is capable of the theoretical maximum of 480 Mb/s.
One candidate is SMSC's GT3200. It has a 16-bit parallel interface, thus it
is possible to interface it with any modern microprocessor. For the ADC
unit, I'd look at Analog Device's ADC selection matrix. They have at least a
16-bit 65 MSPS (Million samples per second) device and a 16-bit 3 MSPS
device. If your sampling rate of 4 Mhz is absolute, the 65 MSPS is the
nearest suitable 16-bit one. The interface is parallel, thus it would be
directly compatible with the GT3200.
If a lower sampling accuracy is enough, AD also offers a 12-bit and 14-bit
10 MSPS devices, both with parallel interface. The upper 4(2) bits of the
USB unit could be used for signalling, if necessary.
I have only experience with the AD's ADC units, and they've been positive
experiences. Dunno about the GT3200, but you could try checking them out.
-Antti Keskinen
U
Ulf Samuelsson
If the board needs/has a sample buffer, then there is no need for the high
speed.
You get 4k samples and then upload it over 12 mbps USB at leasure.
/Ulf
