High speed, high Hfe complementary transistors?
Tim Williams
I'm designing an IGBT gate drive. I need a complementary pair of high gain,
high current transistors capable of switching in under 200ns (Zetex would be
perfect, but all the datasheets I've looked at seem to be in the 600ns
range).
Or (since someone's probably going to post about it whether I like it or
not) you could give a suggestion for a high/low side (half bridge) IGBT
driver rated 600V.
Through hole suggestions please.
Tim
F
Fred Bartoli
range).
driver rated 600V.
Use the ZTX618-619/718-720 from Zetex. They are absolutly perfect for this.
The timing you're mentionning are not switching time: they include the
storage time as well. More, these times are for saturated switching, which
you won't have for a CC output stage and a capacitive load. You'll be in the
few 10s of ns range.
Tim Williams
"Fred Bartoli"
this. The timing you're mentionning are not switching time: they include
the storage time as well.
Ok, but if the follower had to respond in the opposite direction in under
0.5ns, wouldn't one transistor turn on significantly faster than the other
turns off, causing shoot-through?
(Yeah, it won't, but if there were say 40nH in series with a non-resistive
gate capacitance, hmm that could never happen anyway with all the resistance
present...)
which you won't have for a CC output stage and a capacitive load.
You'll be in the few 10s of ns range.
True, I'll be hard pressed to saturate a follower, especially for much of
the entire cycle given a capacitive load.
Thanks!
Tim
F
Fred Bartoli
Tim Williams said:
"Fred Bartoli"
0.5ns? And for IGBT drivers? Why not asking for ps?
Do you understand that 0.5ns is 15cm light travel?
Sorry to say that, but I guess you have to get down on earth and better
understand all the details of how your bridge works, where the parasitics
are, how to wire your system to deal whith them,... Then you'll get more
realistic figures, much more than pulling them at random from your hat.
Jim Adney
"Fred Bartoli"
Oops, 0.5µs.
No, I think it's really much closer to 0.5 nSec.
c is approx 1 ft/nSec. 15 cm is approx 1/2 ft.
That's in vacuum, though, so it will be slower in wires, but only by
25-35%.
