High temperature superconductors and radiation screening effect?
conundrum
Hi all.
I was reading the latest article about the latest research on magnesium
diboride with the possibility of using similar materials to achieve Tcs
of above 200K, and suddenly had a thought.
It has been well established that superconductors exclude a magnetic
field, an effect which extends into the realm of radio waves and
visible/infrared light.
So it occurs to me that a simple method of detecting candidate
materials in a bulk sample would be to affix said sample to a Peltier
module with a temperature sensor, with a radio emitter (possibly as
simple as a Gunn diode) and detector assembly to detect changes in
transmission and/or reflection as well as interference patterns.
Even a few parts in a million of a near-room temp material should
affect the transmission of radio signals through the material at the
critical temperature, where an inert sample will have no detectable
effect.
Has anyone published a paper concerning this possibility?
Thanks, -A
Yes, it's called 'diamagnetism' and in addition to superconductors,
it is common to all conducting materials at high frequencies.
The extension of diamagnetism to low frequencies (and DC) is uniquely
strong
in superconductors; at RF, the superconductor behavior is not unique.
The history of TTF-TCNQ is a case example that might be worth looking
into;
as long as folk were making AC measurements, it looked like a
superconductor.
It wasn't one. That was around the early 1970s, as I recall.
