sudheervemana
- Jan 1, 1970
- 0
Hi all,
In my application board we are using TIDSP's
TMS320LF2407A micro controller which requires 3.3v supply.we are
generating an 3.3v in the board by using an switching regulator
through 24v supply input from the external.when i am trouble shooting
the regulator,the output of the regulator which is 3.3v mistakenly
gets 24v supply . i think the controller power pins may get this 24v
,which actually should require 3.3v supply.I want to know whether my
processor is working fine or not.can any one give me your suggestions
,and also clear me how to verify my controller ,whether it is working
or not.
what are the minimum things that are required by an controller
to work,like all the power pins ,reset pin verification and external
crystal that is used to drive the internal oscillator.one more thing
is in my board all the power pins are placed with an by-pass
capasitors ,if any one of the capacitors gets failed ,the power will
go the ground ,i want to know how to find out the shorted or dead
component.please give me your valuable suggestions to find out the
problem.
With Regards,
sudheervemana.
or not.
problem.
With Regards,
sudheervemana.
