How best to drop ~180V?
rjtucke
I have a tube power supply that is putting out 520VDC. I need 350VDC
(at ~80mA) maximum. I am trying to think of a creative way to drop the
voltage. So far, here's my list:
* find a really big regulator IC
* massive resistive voltage divider
* massive diode voltage dropper
Any thoughts?
Ross
Phil Allison
"rjtucke"
** 6 x 5 watt zeners in series - 28 volts each.
Mounted apart on a tag strip for heatsinking and ventilation.
BTW 520 - 350 = 170
........ Phil
John Popelish
Any thoughts?
Is the 520 volts from a transformer that also powers filaments?
Does the transformer that produces the 520 volts have any primary taps?
Does the filter include a choke?
Jon
A switching regulator (buck converter) would do the job without heating
your house in the process.
Jon
W
Winfield Hill
rjtucke (Ross) wrote...
the voltage. So far, here's my list:
Phil suggested a string of zener diodes in series. But dropping
a fixed voltage exacerbates poor voltage regulation by keeping all
of your source variations, compared to your lower output voltage.
John asked if the transformer had taps, or other secondaries that
you could use to modify the ac before rectification. That's good.
I'll suggest you use a HV regulator with a feedback loop. It has
to be mentioned you could make it using a large vacuum tube. :)
I'll be conventional (I know you asked for a creative way, but...)
and suggest a power MOSFET pass element. The FET should be rated
for 600V and be able to safely handle 180V * 80mA = 15W with a hot
heatsink, and much more power under short-circuit conditions.
Checking the DigiKey catalog for an inexpensive part, I spied the
IRFPC40 at $3.30 (it's a lead-free version, but you can solder it).
http://www.irf.com/product-info/datasheets/data/irfpc40.pdf (Yes,
there are much more capable MOSFETs, but they cost a lot more too.)
The irfpc40 is rated for 150W max with a 25C heatsink, but lowering
the maximum junction temperature to 125C, and assuming a 60C max
heatsink temperature, the dissipation capability is reduced to
(125-60)/(0.83+0.24+0.33) = 46 watts. The last two terms come from
adding an insulator with heat-sink grease (the FET's case will be at
+520V, whereas you should have the heatsink bolted to the chassis).
To insure operation at 520V 80mA, we'll pick a 150mA current limit.
Passing 150mA while dropping 180V creates 27 watts of dissipation,
nicely under our 46 watt limit. But during a short-circuit your
regulator will have to limit the current to under 46/520 = 88mA.
We'll choose a nice cool 60mA, which means we'll need a "foldback"
current limiting circuit with a 2.5 ratio, which isn't very hard.
We discuss foldback current-limit designs in AoE pages 316-317.
There are multiple safety margins in all the specs above, so your
regulator should work well under abnormal conditions, like high
ac-line voltage, etc., or other mistreatment.
Because you're regulating down from a voltage considerably higher
than the output, your design can benefit from two simplifications:
You can use an N-type FET source follower, for easy feedback-loop
compensation, and you can use a simple resistor pullup to drive
the FET.
Over the years I've posted several suitable ASCII circuits here on
s.e.d., but Googling for a few minutes this morning didn't reveal
one, and I have to leave for work now. But if you're interested
in this approach I'll look further later on, or type up a new one.
K
Ken Smith
Any thoughts?
An SCR based phase controlled switch (light dimmer) in place of the
existing rectifier could do it.
The power you need is within the practial range for using a linear
regulator. You will need a good heat sink on the pass element. Chances
are, a simple zener diode + power MOSFET design would be good enough. The
350V zener would be a string of lower voltage ones. You will likely want
to make it have foldback current limiting.
If you are making a bucking switcher, consider adding a small power supply
that flys up and down on the MOSFETs source. This way, you can run all
the electronics of the switcher on that. If you do this with a small
mains transformer and bridge rectifier, remember that there will be lots
of capacitance to couple RF noise through to the mains input.
Phil Allison
"Winfield Hill"
the voltage.
(snip massive overkill solution)
** You haven't got a fucking clue what the app is have you - Win ?
Never stops you from make a whole string a unjustified assumptions.
Ever heard of "Occam's Razor" ??
......... Phil
Michael A. Terrell
Who hasn't? Its just too bad that it doesn't have a sharp enough
edge for you to slit your sorry throat and spare the world all your foul
mouthed rantings.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Phil Allison
"Michael A. Terrell"
** This asshole is a criminal psychopath.
......... Phil
Michael A. Terrell
........ Phil
As usual, you have absolutely nothing worthwhile to add, so you throw
in one of your tired old cliché replies.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Phil Allison
** This stinking asshole is a criminal psychopath.
An autistic and a schizophrenic.
......... Phil
Paul E. Schoen
Any thoughts?
Ross
The most efficient way would probably be a PWM circuit, but it might be too
complex for a simple application. An SCR or triac phase firing circuit on
the transformer would also be efficient.
A resistor and zener is the simplest, but 80 mA x 180 volts is 14 watts in
the series resistor. The zeners will dissipate about twice that with open
circuit, until the load draws power. OK if you have enough power and space
and no heat problems.
A creative low power solution might be to use a voltage doubler using a
capacitor (C1) on the transformer output, two diodes, and a final filter
capacitor (C2), shunted by a 350 volt zener stack. You can choose the
capacitor C1 so it can supply just about 80 mA into the zeners, and when
the load is connected, it will just barely drop the zeners out of
regulation, and very little power will be dissipated in the regulator.
However, the transformer RMS current may be greater than 80 mA, so it may
get hot.
Paul E. Schoen
www.pstech-inc.com
Michael A. Terrell
........ Phil
Yes, Phillys, we've all seen your medical records, so you don't have
to remind us every day. We know that you're the descendant of the early
Australian criminals, and the results of so much inbreeding that you
can't function in any normal social setting. Now be a good little girl
and turn the damn computer off before your boyfriend comes home drunk
and beats the living shit out of you, again.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Phil Allison
"Michael Asshole Terrell"
( snip psycho abuse)
** This Terrell asshole is a criminal psychopath.
An autistic cretin & a paranoid aggressive.
Paranoid schizophrenia is incurable.
......... Phil
Michael A. Terrell
"Hi sailor" Allison wrote:
SNIP
Give up, you useless little used vibrator tester, you are the dumbest
piece of garbage on usenet, but the frog is gaining on you. He'll soon
outrank up on the Usenet dipshit scale. I'm amazed that you can cut and
paste your crap while testing a couple vibrators at the same time.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Rich Grise
I did this once for 24V 0-40A; it was a battery charger. I used a 68HC11
to monitor the output voltage and current and time the SCRs firing. The
SCRs were on the secondary, of course. But I don't think I personally
would try it with a 520V transformer, but that doesn't mean it isn't
doable - I'm just chicken. ;-)
Good Luck!
Rich
Phil Allison
" Michael Asshole Terrell"
( snip more psycho abuse)
Paranoid schizophrenics are incurable.
....... Phil
Michael A. Terrell
...... Phil
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Roy L. Fuchs
Why do you insist on posting stalker like, off topic, retarded baby
bullshit to this technical group, you stupid fucktard?
Phil Allison
"Roy L. Fuckwit"
** A criminal psychopath called Terrell is stalking me
- you FUCKING MORON.
......... Phil
