How do I calculate a battery internal resistance?
royalmp2001
I am looking at various 9V rectangular batteries, notable Duracell.
If I know the capacity in mAH, can I calculate the internal resistance
somehow?
Thanks, guys.
Greg Neill
somehow?
Thanks, guys.
You can measure it by observing the voltage drop when
it is loaded with a known resistive load. First measure
the unloaded voltage, then the loaded voltage. Let's
say that the known load resistance is 100 Ohms, and
the voltage reads 8.85V when the load is applied.
The internal resistance is then (9V - 8.85V)*(100 Ohms)/9V
Or you could go to the manufacturer's web site and look
for battery technical data sheets. For example, the
Duracell 9V spec sheet can be found at:
http://www.duracell.com/oem/productdata/default.asp
Slavek
Rule of thumb is ~0.2R per alkaline cell of new battery; so 9V it is
built from
6 cells that gives ~1.2 to 1.5R;
Measure the best ;
Datasheets from Duracell the next.;
