How do I program rfid tag?
I have a parallax rfid card reader and some blank tags. Does anyone
have any information on how to program the tags without using some
expensive equipment. Is there any thing that would work with windows
or linux software through a serial port for example? Any help would be
appreciated. Thanks.
What is the intended use of the rfid tags?
Jan Panteltje
Same as barcode, but with more info.
They will put these in passports too here, together with digital fingerprint
and picture.
The tags in theory allow you to be traced wherever you go (with enough sensors),
to know whatever you buy etc.
In a later stage you will be injected as newborn with a 100GB flash chip that
can be read from satellite :)
Even later you will be replaced by a chip, the machines would have won.
Jan Panteltje ha escrito:
I thought it may be interesting to learn how they work. I actually
built one of the projects I found in MAKE magazine. Everything seemed
to go well following the schematic. The only issue that I have is with
the capacitor that is used. It's shown the picture but it doesn't
explain what rating needs to be used. It powers up just fine but one
small problem, nothing to read. I also bought two blank cards but of
course they need to be programmed. I know that there are some pricey
standalone programmers out there so I prefer to use something that
would work with software on the computer. Any ideas? Who
knows...programming the cards with my name and reading it back.
Nothing complicated.
