Jeff
- Jan 1, 1970
- 0
Just curious...Are BGAs mounted on boards with aqueous flux? Can the rinse
water get under there to removethe flux?
Jeff
Jeff
Jeff
James Meyer said:I could tell you how I wash my balls, but then I'd have to change my
name to Genome.
Jimnome
Genome said:Would that be a ladle, a toothbrush and the morning water from an overnight
Steradent soak?
DNA
Jeff
rinse water get under there to removethe flux?
Jeff
Vincent Himpe said:If you go to real mass production assembly they will use vapor phase
soldering that leaves no residue whatsoever. ( the board exits out of the
oven completely clean )
Vapor phase uses heat transfer liquids. since the flux is soluble in this
liquid and dissolves before the solder melts all flux is removed
automatically.
