how much power does this take?
RB
Approx how much power, in kw, does a 4 ton air con unit draw? Don't need a
precise number. Ballpark will do nicely.
SQLit
running or starting?
starting current can be 6 times running current.
The other posters math is right on
except there are ancillary fans that need to be entered into the equation.
Since you do not state the age of the unit. I could be anywhere from 24 amps
to more than 30 once it is up and running.
Anthony Matonak
I'm told air conditioners move more energy than they consume.
The ratio varies depending on the hot/cold temperature difference
and the model of the air conditioner but I've heard 3/1 bandied
about quite a bit. This would mean that it takes 1/3 the energy
that it moves.
So 4 ton = 4x12000/3412.2/3 = 4.7 kW.
Most air conditioners don't run continuously, of course, but
around here (Los Angeles) it's not uncommon for the central
air in a house to consume anywhere up to 50 kWh/day with
24 kWh/day being around the average.
Anthony
Me
the seventh sign said:
3412.2Btu/hr 1kw
1 ton 12000 Btu/hr 3.516792685kw
4 ton 48000 Btu/hr 14.06717074kw
Check the math please.
TSS
Well the math is ok but the premis is suspect. The OP wants to know
how much electricity is is going to take to run his AC unit. Not how
much energy is required to be moved to cool his house. There is a big
difference in how much energy he has to move to cool his house and how
much energy it takes to move the BTU's from inside the house to outside
the house. You calculated how many BTU's he has to move and then
converted that to KW's, but that isn't what he asked for. He wants to
know how much it is going to cost him in USDOLLARS to keep his house
cool, each and every day, and that calculation is going to require a lot
more information than you started with........ but nice try anyway....
Me
...You calculated how many BTU's he has to move and then
converted that to KW's...
No. He calculated how many Btu PER HOUR he has to move and
converted that to kW. Let's not confuse power and energy.
Nick
daestrom
But the OP question was, "How much power, in KW, does a 4 ton A/C draw?"
None of the posters in this branch have considered the COP of the unit, and
that is the direction 'Me' was starting to go.
A 4 ton unit is capable of 48,000 BTU/hr. When it runs, if it has a SEER of
about 10, then it probably draws about 48,000 / 10 = 4,800 watts. If it
runs *continuously*, then it would use 4.8kW * 24h = 115.2 kWh of energy
each day.
But it probably won't run *continuously* (if it does, it's pretty
undersized), so the energy usage will be less.
daestrom
Paul Crumpler
Depends greatly on the type of AC, but a 4 ton ac will require between 6 and
8 kW.
Jim Baber
Jim Baber has a question for Paul:
You seem to have some info I am interested in. Would you be willing to
tell where you got the 4 to 8 kW number, it seems very vague.
I am looking for a table that would show that info related to Mfg,
tonnage and SEER # for central to lookup my A/C kW
