How to confirm a TV tuner is at fault?
alitonto
re Teac TV ctm687 This is further to my previous post 17/7/2005.
After performing many tests on the circuit I find the AGC voltage to be
higher (7.84) than it is required at I/C TDA8305A (3.9).
I am not sure what other things to try before actually desoldering the
tuner.
If I can obtain the schematic of the tuner which shows what voltages to
expect at it's outputs and these match the readings I measure on the
tuner whilst still connected to the circuit board, will this confirm
the tuner being faulty?
Any thoughts on this?
Thank you
Al
Phil Allison
"alitonto"
tuner.
** Try pulling that AGC voltage down to 3.9 volts or so.
Use a suitably chosen resistor to ground or maybe a 3.9 volt zener.
See what happens.
......... Phil
alitonto
Thanks Phil
Although your suggestion sounds interesting, are you suggesting that
tuners should have a voltage adjustements in place?
I am sorry but I am confused as to what is there to gain from trying
your suggestion.
I guess what I am trying to establish is if the higher voltage
appearing at the AGC pin could be caused by another circuit part or IC
etc.
Thanks.
Phil Allison
"alitonto"
Please do not TOP POST !!!!!!!
Thanks Phil
your suggestion.
** Try it anyhow - the only way to learn.
etc.
** If the pic comes up lovely - what does that prove ?
K
Ken Taylor
alitonto said:
Thanks Phil
your suggestion.
etc.
Thanks.
It's a test. If you drag down that voltage to 3.9V and the tuner works, you
know it is not at fault.
Ken
Why do you think the AGC is the problem and not a symptom?
Do some research to find out what the function of the AGC voltage is
for and how it works?
alitonto
Thank you all.
I would like to do this test but I need to check about correct
procedure: would it be proper to solder a 3.9 zener diode with the -
end to the tuner's AGC pin and the + end to the tuner's ground.
I understand the idea is to clamp the voltage to 3.9; is this right?
I will wait for confirmation.
Al.
alitonto
Hello dkuha
Your comments have aroused my curiosity,
I am beginning to suspect the I/C to be shorted;
Am I in the right direction?
Thaks
AL
Phil Allison
"alitonto"
Hello dkuha
** Just keep saying slowly:
" The rain in Spain stays mainly in the plain ...... "
............. Phil
Phillip Allison
"alitonto"
............ Phil
Well, **** me! The looney thinks that he is Professor Higgins!!!!!!!!!!!!
Now that you are thinking about it. The AGC voltage goes high to
increase the gain of the rf amplifiers inside the tuner to compensate
for a weak rf signal. Most go as high as 9v DC.
If you unsolder the AGC pin off the tuner and feed a direct 4v DC to
it, you will probably find that the signal gets worse as the gain of
the rf amplifer is lower.
If the tuner is in fact tuning all channels correctly and it appears
they are locked on but just snowy. Odds are very high that the problem
is in the rf stage of the tuner.
Do you have lightning where you live?
If that is a possibility, pull the tuner from the tv, carefully remove
the shields without prying on the internal parts of the tuner.
Visually inspect the front end (where the cable signal goes in). Look
very carefully for any signs of burnt traces, arc marks, or bad solder
connections to the grounds. Then do a good visual to the solder
connections to the pins of the tuner and the rest of the grounds.
Unless you have a tv tuner signal generator with if output, there is
little more you can do at your end beyond swapping out the tuner.
Instructor David
F
Franc Zabkar
Thank you all.
Al.
AGC = automatic gain control
If the signal from the tuner is low, then the AGC circuit attempts to
compensate by increasing the gain of the RF amp. Conversely, if the
signal is strong, then the AGC circuit reduces the gain. Under typical
(ie good) signal conditions the AGC circuit would be producing a
control voltage of 3.9V. The gain is automatically controlled via a
closed loop feedback system that monitors the signal level at the IF
stage.
If you suspect an AGC fault, then disconnect the AGC input and connect
the tuner's AGC pin to a potentiometer via a series resistor, as
follows:
tuner AGC pin o---- R ------|
tuner ground o--/\/\/\/\/\--o tuner supply (+12V)
potentiometer
- Franc Zabkar
alitonto
Phil said:
"alitonto"
............ Phil
How many times do I have to repeated? so far nothing has happened> just
kidding. I have now realised-thanks to many replies- that my supply
voltage to the AGC is too high, so now I will investigate further in
the right direction and I will report back findings.
Thank you all
AL
rrobor
Thank you all
AL
rrobor
Thank you all
AL
Have you ever thought that it was your antenna or antenna lead. It
plays VCR tapes OK, yet the channels through the VCR are snowy. Duh.
You got a faulty TV tuner and a faulty VCR tuner or a faulty antenna
lead. Guess what its gonna be.
rrobor
Try the antenna lead its not the TV, if you sit down with all the facts
you have posted it has nothing to do with the TV, stake my house on that
Tom MacIntyre
Isn't a typical AGC voltage about 8 volts?
Tom
PS - I'm NOT sorry for the top-post. If it fits the screen...
