How to disassemble a Tektronix P6013a probe?
I just got a new old stock Tek P6013a probe and I noticed the bnc connector
on the probe body is a little loose. I'm guessing there's a lock nut on
the inside and I'd like to tighten it up before using it and possibly
twisting off a wire on the inside. How does the probe body come apart so I
can tighten up that bnc? Is that possible?
Thanks, Dave
Michael Kennedy
I'd just put a piece of glue lined heat shrink on it, that way you don't
risk ripping the wire out your trying to protect.
- Mike
Phil J
Just hold the light gray front of the body and unscrew
the dark part.
Then push the dark gray tip back through the light part.
That will reveal a metal cylinder. Remove the small screws
holding the cylinder, that will reveal the back of the bnc.
Phil J
the dark part.
Phil J
That was way to simple, thank you! I should have expected something that
elegant and direct from Tektronics.
Similar threads
