In the management and interaction of embedded devices, the application based on Web mode has become the mainstream. This kind of server not only occupies small resources and runs efficiently, but also can dynamically generate page content according to actual needs. For users, they can realize the remote management, status monitoring and function control of embedded devices only through the commonly used Web browser, without installing additional software or complex configuration.
BOA is a lightweight, efficient, and embedded Web server known for its minimal resource consumption and straightforward configuration. It is particularly suited for devices with limited memory and processing capabilities, providing essential Web functionalities. This article describes how to port the boa server on the FET-MX9352-C platform.
How to Compile Source Code?
Download address:
http://www.boa.org/
1. Install dependent libraries
sudo apt-get install bison flex
Unzip the source code in Ubuntu
$ tar xvf boa-0.94.14rc21.tar
cd boa-0.94.14rc21/
Modify the boa source code
Modify src/compat.h
find
#define TIMEZONE_OFFSET(foo) foo##->tm_gmtoff
Modify to
#define TIMEZONE_OFFSET(foo) (foo)->tm_gmtoff
Otherwise, an error occurs:
util.c:100:1: error: pasting "t" and "->" does not give a valid preprocessing token make: *** [util.o]
error 1
Modify src/log.c
find
if (dup2(error_log, STDERR_FILENO) == -1) {
DIE("unable to dup2 the error log");
Modify to
/*if (dup2(error_log, STDERR_FILENO) == -1) {
log.c:73 unable to dup2 the error log:bad file descriptor
Modify src/boa.c
find
if (passwdbuf == NULL) {
DIE(”getpwuid”);
if (initgroups(passwdbuf->pw_name, passwdbuf->pw_gid) == -1) {
DIE(”initgroups”);
Modify to
#if 0
DIE(”getpwuid”);
DIE(”initgroups”);
#endif
Otherwise, an error occurs: boa.c:211 - getpwuid: No such file or directory
Set environment variables and compile
. /opt/fsl-imx-xwayland/6.1-mickledore/environment-setup-armv8a-poky-linux
./configure --host=arm-linux
make
aarch64-poky-linux-strip src/boa
At this point, the boa has been cross-compiled
Expected file path examples/boa. conf and SRC/boa
2. Modify boa.conf
vi boa.conf
(1) Group modification
Modify Group nogroup
to Group root
(2) User modification
Modify User nobody
to User root
(3) Modify DocumentRoot
DocumentRoot /var/www
(4) Modify ScriptAlias
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
(5) ServerName settings
Modify #ServerName www.your.org.here
Otherwise, an error will occur “gethostbyname::No such file or directory
3. Compile the test file
tar xvf cgi_app.tar.gz
cd cgi_app/
Clean up the files
make clean
$CC -o app.cgi cgi_app.c cJSON/cJSON.c
Generate app.cgi
4.Arrange to the development board
To create the directory, enter the following command on the development board.
mkdir /usr/lib/cgi-bin
mkdir /var/www
mkdir /etc/boa
mkdir /usr/lib/cgi-bin/ Table of ContentsPut app.cgi in the /usr/lib/cgi-bin/ directory
Put index.html, xmlhttpreq.js to /var/www/ folder
Put boa.conf in the/etc/boa/directory
Place boa in the/usr/bin/directory
Place the mime. Types in the/etc/directory
Modify permissions
chown root:root /var/www/*
chown root:root /usr/lib/cgi-bin/app.cgi
chmod o+x /usr/lib/cgi-bin/app.cgi
chmod o+r /usr/lib/cgi-bin/app.cgi
Turn off the original network services
Because 9352 self-started lighttpd services, ps aux | grep http can see his process ID. To disable the startup of the Lighttpd service, vi /lib/systemd/system/lighttpd.service change line 8 and 9 to
#ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf
#ExecStart=/usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf
Create a log file
Vi/etc/autorun. sh Write this in mkdir/var/log/boa and restart
Start the boa by entering the following command on the development board.
boa
The computer and the development board are directly connected through the network cable, and the computer opens the browser to access the IP of the development board.
http://192.168.0.232/
Download address:
http://www.boa.org/
cd boa-0.94.14rc21/
Modify src/compat.h
find
Modify to
error 1
Modify src/log.c
find
Modify to
Modify src/boa.c
find
DIE(”getpwuid”);
DIE(”initgroups”);
Modify to
#if 0
DIE(”getpwuid”);
DIE(”initgroups”);
#endif
make
2. Modify boa.conf
vi boa.conf
to Group root
Modify User nobody
to User root
cd cgi_app/
Clean up the files
make clean
Generate app.cgi
mkdir /var/www
mkdir /etc/boa
Modify permissions
Create a log file
boa
