Michael
- Jan 1, 1970
- 0
Hi - I'm going to be using some N-FETs to turn on/off (from the high
side) a large (10-30A), grounded load that is being powered by a ~55V
power source. I would like to be able to switch them with 5V signals.
Now, I am no genius, but I'm pretty sure I can't drive the gates with
5V when their drains are at 55V. So somehow I need to get a voltage
say ~10-20V above the 55V power source that is being switched. I'm
favoring a boost converter, just because that is the technique I'm
most comfortable with. Specifically, it looks like I could use a
Linear LT1171HV (http://www.linear.com/pc/productDetail.jsp?
navId=H0,C1,C1003,C1042,C1031,C1061,P1316) to get that supply pretty
easily. I should mention that on this board I will probably also have
some sort of lower voltage supply, like maybe 12V or 5V or something
along those lines. Also, I should mention that on this one PCB I'll
have probably 3 of these switching circuits.
But once I have this power source, how do I switch the gate, and how
do I do it quickly? The hard thing is that I want to be able to switch
this stuff with TTL level signals. So, right now I'm thinking about
using an op-amp, say something like a TI OPA445 (http://focus.ti.com/
docs/prod/folders/print/opa445.html), though probably not that chip as
it seems to have pretty limited availability right now. The OPA445's
15V/us typical slew rate should probably be fast enough. I'm trying to
avoid overheating the FET while it is switching from on to off and
vice versa, hence the desire for fast switching speeds.
Now, to make things a bit more interesting: The power source is going
to be fairly variable. It could be anywhere between about 10 and
55VDC. That means my DC/DC converter needs to be smart enough to have
an output voltage that is ~10-20V higher than the input voltage. Or
the gate switching circuit needs to be smart enough to bring the gate
to about 10-20V higher than the input voltage. I tried working out a
circuit to handle the feedback for the DC/DC converter to give it an
output voltage of 20V higher than the input voltage, but, unless I
messed something up, it looked like it'd require an analog multiplier
and an op-amp, which is just getting complicated. So right now I'm
thinking it'd be better to take care of the variable input voltage
with the gate switching circuitry. I can't seem to come up with a
circuit that will do this with just a single op-amp - everything I've
thought of so far has needed two op-amps - but surely there's a way to
do it. If not, oh well - it's not the end of the world, but I would
like to use as few of these high voltage op-amps as possible as they
seem to be pretty spendy.
So - do you think this is the right direction for me to be going in?
Or can anybody suggest a better method?
Thanks guys!
-Michael
Thanks guys!
-Michael
