How to safely wire or utilize a switch
Status
Not open for further replies.
Healthyou
Feb 28, 2015
I want to use an old switch on a lamp that I'm building but it can be easily disassembled by a child. Is there a way to wire the switch in without directly exposing it to 110v ? Would I use a relay or is there a way to wire to prevent any possible shock just in case someone accessed the inside?
KJ6EAD
Aug 13, 2011
1,114
If you're trying to make a lamp that's intrinsically safe then supply it with low voltage only and work with that to get the light output you want. Other than that I'm not sure what you're trying to accomplish.
Y2KEDDIE
Sep 23, 2012
259
One goood way to prevent shock would be to buy an inline GFI (Ground Fault Interupter)., and install at the plug end of your appliance..
You see thjese on Mains powered pressure washers, and other equipment used outside and/or around water.
KMoffett
Jan 21, 2009
723
Y2KEDIE,
A GFCI only works if there is an alternate path to ground from the hot line. Taking apart a line operated lamp would just expose the "kid" to line-to-neutral electrocution
Healthyou,
How about a photo of what you are trying to do.
Ken.
Y2KEDDIE
Sep 23, 2012
259
Sorry But your wrong.
A GFI works by measuring current in only the current carrying two legs: L1 and L2. It does not use the safety ground for operation. It uses differential measurement. This is what makes it perfect for the application above.
KJ6EAD
Aug 13, 2011
1,114
So as long as I stand on a dry insulative surface like most interior floors while holding the line in one hand and the neutral in the other, the GFCI will see both legs in balance and continue supplying current to my cooking heart!
KMoffett is correct. A GFCI is not a panacea.
14,487
This whole thread is very dangerous and is closed
Status
