How to solve NP-problem using hydrodynamics of electrons
Let's take some NP-problem: we have a verifier which can quickly say
that given input is correct or not, but there is huge number of
possible inputs and we want to tell if there is a correct one (find
it).
Imagine we have a chip with 'input' and 'output' in which is
implemented (e.g. FPGA):
IF 'input' verifies the problem
- THEN send 'input' to 'output'
- ELSE send next possible 'input' (cyclically) to 'output'
such that this chip uses only basic logic gates - computations are
made in some small number of layers - IT DOESN'T USE CLOCK (we can do
it for some NP problems like 3SAT).
Now connect it's 'output' and 'input' to make a loop.
Such loop will be stable if it has found a solution (which can be
transferred out).
If there would be a clock, in each cycle there would be checked one
input. But without clock it should be pure hydrodynamics of electrons.
If there is a solution, other states would create fluctuations in time
- should be less energetically preferred than the stable one -
physics should quickly solve our problem.
I know - there can be a problem with nonlinearity of transistors? If
yes, there are plenty of technologies, maybe some of them would handle
with it?
This loop computer idea is practically simplified from time-loop
computer idea:
http://groups.google.com/group/sci.physics/browse_thread/thread/c5f055c9fc1f0efb
Tim Williams
Had a similar thought with a friend. Challenge: implement the Mandelbrot
fractal set using an analog computer. So you have two inputs, perhaps -1 to
+1V, representing real and imaginary axes (or if you want to get really
proper, you could do the same with a phasor per se... who cares). You put
this into a function box, which eventually tells you if the point is in the
set (it doesn't converge within some time T), or if outside, how many
"iterations" it took.
Now, the implication that this is an analog computer is that the computation
can be performed continuously (there are algorithms which produce a
continuous set, incidentially) and in the time-voltage domain. Settling
time then corresponds to iterations, or if it never really sits still, it's
in the set or something.
The crazy thing is, desktop computers are easily able to compute to a depth
of a few million iterations, rendering a full screen (a megapixel let's say)
in maybe a minute or less (maybe seconds on the video hardware). If you
assume an fT around 1GHz, that's very roughly 1ns per "iteration", so a
single pixel takes about 1ms to a depth of 1 million, and that's if you have
the required accuracy in that time (which you wouldn't, closed loop settling
time for a normal amp is a couple of fT's).
Even with the possible problems, an analog Mandelbrot computer could be
really interesting...
Tim
Deep Friar: a very philosophical monk.
Website: http://webpages.charter.net/dawill/tmoranwms
it).
<snip>
About the Mandelbrot's set, You might be interested at model of
computing on real numbers by Blum, Shub & Smale. But it's rather
purely theoretical model and as I remember it's main motivation is
belief that it can lead to P!=NP proof.
But I have to admit that I don't see how to create this set using
analog computer?
What I'm proposing is something different - the structure of this
computer is completely digital, but time is analog.
We can think about it as dynamical system which want to minimize it's
energy. It can do it only by proper valuating variables and solving
our problem.
If it will work, cryptosytems we are currently use are in danger - it
could break RSA or find a key which if used on a beginning of an
encrypted file makes output with significant correlations...
I
IanM
analog computer?
our problem.
Cant work for the general case. Google 'local minima' for reason why.
If this class of problems didn't have strong local minima, they wouldn't
be NP problems! There are some arguments that a fully quantum computer
could work that way however your computing device will tend to bounce
around the solution space cycling through a limited (albeit possibly
very large) set of incorrect solutions in an orderly fashion that may
appear chaotic over a sufficiently short timescale.
Tim Williams
analog computer?
The per-pixel routine merely consists of addition and multiplication, which
is quite easy to do with analog building blocks. The x + jy values are
bounded (if they start going unbounded, you know you're not in the set!) so
picking voltages is very easy. The only funny number you get is the depth
count, which can get pretty gnarly after a while (a million is a lot of
voltages to check).
our problem.
Instead of a clock cycle making everything orderly, you must face
propagation delay. Clock is necessarily longer than propagation delay, so
you will chug faster, but you can't necessarily do the same computations the
same way.
Tim
It's not classical computer: while removing the clock/synchronization
we are destroying the order and releasing all it's statistical,
quantum properties to make what physics do the best: solve its partial
differential equations. Now it became continuous and so it can go with
energy gradient to some local minimum, but the only local minimals are
stable states (solutions). Every other is extremely unstable -
electron fluid won't rest until it find a solution. The statistics,
differences between propagation times will create extremely fast
chaotic search for it.
I'm not sure, but it could find solution qualitatively faster than
classical computer.
I don't know to much about analog computers... It's easy to add, make
some averages, integrate, differentiate signals ... but how to make
even multiplication? Use transistor? it's extremely nonlinear...
The other thing is that if You are dividing the picture into blocks -
discretize it ... You get practically the same as in digital
approach...
Jarek
Archimedes' Lever
Tim
Sounds like a quantum box could do it in a couple of nanoseconds.
I owned "Fractools" way back when EGA and VGA were terms that meant
something graphical was about. It was one of the first authored apps for
it. Now, even the free stuff blows it away in many areas. I liked how
it calculated each pixel though, as opposed to all these today using
bitblts. The current crop are grainier than my old app was because of
the calculation method, and final resolution of the image. Nothing these
days gives a sharp focus on the final image. All the fringes get munged
by 'soft math'. Fractools did EVERY pixel. Some pictures took the whole
day to calculate. Running it today would likely do it in minutes. I
should dig it up and run it on a virtual machine.
GeForce Gold or Platinum is a good color organ app for your media
player. It overlays graphical creations on top of your photos and such,
and has several fractal routines that run. It has some really far out
serpinsky routines.
Sort of analog, considering that it is analog music that stimulates it
into action. Way better than simple fractals.
Get the trial, and then wait out a long time, and he'll offer you the
full package for like $24 instead of $35.
