ruleworld
- Jan 1, 1970
- 0
i want to use stk439 amplifer which has 42 watt output with 7 watts
speaker. how can i do it without blowing up the speaker.
ruleworld said:i want to use stk439 amplifer which has 42 watt output with 7 watts
Jan said:Perhaps a resistor attenuator.
I thought he meant he still wanted the original peak output.
Just shows, the question was poorly worded.
Realistically you can't (easily).
You could add an average power measurement coupled to a VCA to reduce gain if
the power goes above the 7W average but it's way easier to find a more suitable
speaker.
Graham
Just don't turn it up too loud - ever - and it should be OK.
The power ratings on many consumer audio products are complete lies anyway,
so depending on whether the speaker manufacturer or the amplifier
manufacturer was the bigger liar, the real power capabilities of the two
devices could be very different from what they are rated at.
If you will not be in control of the volume knob yourself at all times, but
rather someone else like a child or a careless person will be using the
setup, then you might need a way of limiting the output of the amplifier.
One way to do this would be to connect a "Polyswitch" in series with each
speaker. The size of the polyswitch will need to be chosen appropriately
for the speaker. The polyswitch might get hot under fault conditions and
so it should ideally be installed in a metal enclosure (perhaps inside the
amplifier box) to prevent the risk of fire.
https://secure4.vivid-design.com.au/jaycar2005/images_uploaded/polysw...
Chris
can i limit the volume somehow. maybe placing a resistor in series
with the volume control variable resistor?
Possibly, but if you have different signal sources like CD player, MP3, etc.
that put out different sized signals, then it might be hard to find a limit
that is always appropriate. It also depends on what circuit is used for
the volume control of your amplifier, in some cases just a resistor in
series might not work well.
You could just not turn it up too loud, as I said before.
Chris- Hide quoted text -
- Show quoted text -
ruleworld said:can i limit the volume somehow. maybe placing a resistor in series
It seems you still haven't 'clicked' the most important one.
The AES method is to measure power rating with band filtered white noise Why do you
think say measuring at 400Hz or 1kHz would make any relevant difference ?
How many 'DC speakers' do you know ?
Why are you being so silly ?
Graham
D said:Maybe it's lack of sleep...
I didn't know how (globally) speaker power rating is tested..
(It's probably a cheapo 7W speaker from China..)
but I do know that whatever the test...it's probably a test of how hot
the voice coil can get.
That or when there's too much distortion...
I suspect DC can be roughly used to test voice coil power dissipation.
It's usually determined by some form of thermally related for sure.
Well NO.
Because a lot of the cooling effect comes from voice coil motion in air that removes the
heat. DC means no (long term) motion.
Graham
