HP Laserjet III P problem
  • Thread starter Stefan Toftevall
  • Start date
Stefan Toftevall
Hi everyone,
My good old laserprinter suddenly refuse to print with the display
showing: "50-Needs service". Anyone know what is wrong?
I heard somebody say it has got an internal counter, and after a
certain amount of printouts, it display this message though it must
not be anything wrong. The counter needs reseting in some way.
Anyhow, any advice is appreciated,
Regards, Stefan
Lee Babcock
Stefan said:
Hi everyone,
Regards, Stefan
This code indicates a problem with the fuser. This model series is
famous for an underrated capacitor in the fuser circuit causing this
code. I'm not a tech, but I'm sure someone here will be able to help
you further on this.
BTW, a simple check on google gives:
http://www.all-laser.com/cgi-bin/webc.cgi/error50.html
Regards
Lee in Toronto
Sarah
Sounds like a motor assembly, pretty common, its deep inside the
machine = $$$.
get another printer at ebay.com if you want a cheap one.
James Sweet
Stefan Toftevall said:
Hi everyone,
Regards, Stefan
50 is a fuser error, there can be several causes but 99% of the time it's a
small usually green electrolytic capacitor on the board that controls the
fuser lamp (it's near the power supply). If you get that board out and look,
you may even find that the cap is leaking or bulging. Replace it, reassemble
and you should be good to go. Those are very good printers.
Cubzilla
Yep as others have said
the fuser or the PSU cap = service 50
You can check the fuser bulb with a meter should read 20-30 ohms
Ref the counter and all that crap... thats on the larger range of Laserjets
ie laserjet 5si.. laserjet 8000 etc
Regards Cub
Andy Cuffe
Hi everyone,
Regards, Stefan
That error means the fuser isn't getting up to temperature. It could
be a blown fuser heater lamp, thermal fuse, or the control circuit.
Andy Cuffe
[email protected] <-- Use this address until 12/31/2005
[email protected] <-- Use this address after 12/31/2005
Similar threads
Replies
1K
Paul and Paula
Replies
6
2K
Pcaorwb
Replies
6
3K
joe devlin
