HV cables (5kV rated for 200 degrees C)
JosephKK
I am working on a project that legitimate requirement for such cable.
I have not been able to find such as a stock product. I am uneasy
about the temperature rating of EPR and XLPE insulation materials.
JB
There are silicone insulated cables rated for these voltages/temps. We use
them in the lighting industry for cables connecting ignitors to lampholders.
They are not cheap however.
JB
legg
The only UL wire styles rated for 200degC or higher use TFE (1180) or
inorganic (5107~mica) insulation. While silicone may serve to 200C, it
is not employed in UL wire styles above 160degC.
HV cables above 1KV are outside the range of standard UL provenance.
For AC voltage ratings, resistance to formation of corona is important
- again a property of teflon.
http://www.daburnonline.com/CRTHighVoltageCoronaResistantTeflonWire8AWG-18AWG.aspx
http://www.daburnonline.com/2636HighVoltageSiliconeRubberLeadWire200CVW-1.aspx
https://www.alliedelec.com/search/S...294825717&No=10&SKU=369-0054&sid=11BF33A724FA
RL
If you have to use silicone use RTV
