Tom
- Jan 1, 1970
- 0
I have an IBM Selectric 2 Correcting typewriter that works fine except
that several of the letter keys, and spacebar are sluggish and will
stick down for 5-10 seconds. Also the typewriter motor will not start
initially if it has been setting idle for some period (months). After
a short time it will run fine and will continue starting and running
fine until it sits idle for another extended time.
My gut feeling says that it really needs cleaning and lubed as it has
never had that done in the 25 years I've owned it. Any old IBM guys
who know if that is much of a job without a service manual? I've
taken off the cover and the existing lubrication is definitely old and
on the tacky side. Any recommendation on the lube point for the
sticky keys and spacebar? Would sewing machine oil be appropriate
or how about WD40?
I rarely use it (like maybe once a year) and have never used it more
than the occasional home written letter (pre computer). I bought it
from the original owner who also had used it lightly in a home
business. He bought it new in 1973. I was hoping to get it running
again for occasional use without taking it into a shop and probably
spending more than it's worth. Thanks for any help.
or how about WD40?
