ibutton question
simon
Hello all
Just started using the Dallas/Maxim DS1990A with a DS9092 Touch Probe
using a PIC16F505 as the Master. Everything works fine if the PIC polls
the probe and when the Touch Memory is present, the serial number is
successfully read. My question is...
Is there anyway I can 'wake-up' the PIC from Sleep when I place the
DS1990 in the DS9092? In other words, can I get the DS1990A to generate
an interrupt?
Cheers,
Simon
Jamie
simon said:
Hello all
an interrupt?
Cheers,
Simon
if your putting the pic into a sleep mode for what ever reason you guess
you could connect the input signal to an input that can be programmed to
fire off an Interrupt.
the start of this pulse should force the IRQ code to jump rite to the
reading loop etc...
in other words, either program the input line to trig an IRQ when it
goes into sleep mode and then shut it off on the first trigger or
use a different input and tie them together.
etc..
