Identifying an unknown potentiometer
FuZZ1L0G1C
Mar 25, 2014
366
FuZZ1L0G1C submitted a new resource:
Identifying an unknown potentiometer - How to test when printing is worn off, or not sure if Log or Linear taper
A potentiometer is very basically a potential divider, with a center wiper providing the variable resistance between wiper and the end points.
The resistance between the end points does not vary, and is called the resistance 'value' of the component, usually with a tolerance of ± a certain percentage.
'Pots' are also rated with a maximum wattage rating, which must not be exceeded, as with any resistor.
Potentiometers may be single track types or multi-ganged, eg dual gang, meaning that 2...
Read more about this resource...
