Impossible FET or BJT design
I wonder could anyone devise a simple switching circuit using FET's of
BJT's for the following truth table:
Vin | Vout
0V | -10V
+3.3V | -15V
I have four power rails available: 0V, +5V, +15V and -15V.
I have racked my brain for an answer but have failed to find one.
Thanks in advance.
Ross.
mc
(See below)
Vin | Vout
0V | -10V
+3.3V | -15V
Thanks in advance.
Ross.
Let me suggest a subproblem: Obtaining a -10V power rail. Work on
getting -10V first.
You haven't said how much output current is required.
Thanks for the reply mc,
getting -10V first.
I can get the -10V power rail using a potential divider between the
-15V and 0V rails.
The output current required is 100uA.
Ross.
Thanks for the reply Spehro,
Imagine a fixed resistor of, say, 1K to the -15V rail, and negligible
loading. Does that help?
Maybe I'm missing what you are suggesting here but this doesn't seem to
help. I want a switching circuit which when 0V is applied to the
input, -10V will appear at the output. Similarly, when 3.3V is applied
at the input, -15V will appear at the output.
Ross.
Spehro Pefhany
Vin | Vout
0V | -10V
+3.3V | -15V
Thanks in advance.
Ross.
Assuming this is a homework question...
Best regards,
Spehro Pefhany
F
Fred Bloggs
Vin | Vout
0V | -10V
+3.3V | -15V
Your truth table suggests an inverter and level translator. So something
like this:
View in a fixed-width font such
as Courier.
F
Fred Bloggs
Vin | Vout
0V | -10V
+3.3V | -15V
More like this:
as Courier.
Pooh Bear
Why the need for fets ? This is a perfect application for an op-amp.
Graham
F
Fred Bloggs
This is probably even better:
as Courier.
Thanks for the reply Fred,
Is the FET an n-channel or p-channel? Is the drain connected to the
upper part of the schematic or the lower part?
Ross.
Pooh Bear
Ahem ! The *fet* ? How's the course been going ? Missed many lectures ?
Graham
Pooh Bear
Jfet or mosfet btw ?
Graham
Graham,
Fred is using ascii characters to map out a circuit. Drawing the
proper symbol for the transistor is dificult. I can't tell from the
ascii representation of the transistor if it is a JFET or MOSFET.
The application involves switching power supplies to an IC. I don't
want to use op-amps.
Ross.
Pooh Bear
Graham,
I know !
Drawing the
There a few programs available to do this actually.
I can't tell from the ascii representation of the transistor if it is a JFET
or MOSFET.
It's neither. I was (a) pulling your leg and (b) trying to find out if you knew
what it really is.
The application involves switching power supplies to an IC. I don'twant to
use op-amps.
Whyever not ? Admittedly a transistor is cheaper though !
Graham
Rich Grise
Graham,
It's a PNP bipolar.
Good Luck!
Rich
Robert Baer
Ross.
Methinks that there is no FET inthe circuit given, so the answer is
"neither".
Robert Baer
Graham,
Ross.
Don't know how to read a simple schematic?
