Inductance of a Bar Core Solenoid
Stephen
I hope this isn't the stupidest question all week, but here it goes:
I'm trying to determine the relative permeability of a soft magnetic
material by measuring the inductance of a solenoid for which it is the
core material.
My simple plan was to saturate the core using a large permanent
magnet, measure the "air core" inductance, remove the magnet, and
measure the non-air core inductance. I then assumed (and this is
probably the stupid part) that the relative permeability of the core
material would simply be the ratio of these two measurements.
The material of the core in this case is Ni(45%)Fe(55%) whose relative
permeability should be well above 1000 if it was prepared correctly.
My measurements and calculations are giving a permeability value of
~10. Not good.
The core is simply a bar with its middle third wrapped with Cu wire,
and one third sticking out on each end. There is no closure path
other than air for the flux.
Can anyone out there steer me towards a web site where inductance for
such a structure can be calculated. Or if someone out there can
provide the calculations here, that would be even better.
Thanks in advance,
--Steve
John Popelish
Stephen said:
core material.
~10. Not good.
Sorry, but this is a hopelessly bad way to measure such a high
permeability. All the flux passing through the coil passes through a
lot of air as well as the core material, so the air will dominate the
inductance, and slight variations in core permeability (say, between
100 and 1000) will have little effect on the total magnetic reluctance
of the flux path. This test will be a lot more sensitive to core
geometry than it is to core permeability. This sort of test is
usually done of a toroid made of the material in question, to exclude
all other material from the flux path.
Spehro Pefhany
BTW, I'm going to be of no help, but where did you get that Ni-Fe core
material? Is it annealed and otherwise intended for magnetic use?
Best regards,
Spehro Pefhany
Stephen
Thank you very much for this confirmation. After I posted the
question, I continued to look for answers on the web, and found a
treatise on inductance calculations by Marc Thompson that provided the
same answer you gave. I see, now, the error of my ways. In the end,
this is good news for us, since we were thinking that our material had
very bad magnetic properties, and now I see that another test is
required.
Thansk again!
--Steve
Stephen
Best regards,
Spehro Pefhany
This material was electroplated. We didn't use any magnets to align
it during the plating process, but the B-H loops look reasonably good,
with Hk values in the 6-8 Oe range.
--Steve
