Initializing an ENC28J60
Josef Moellers
I'm currently trying to convert a "NET-IO" board of the German shop
"Pollin" into a Serial-to-LAN-adapter and learn something on the way (so
"use the ethersex code" is not an option ;-).
I have disassembled the original code (which allows access to 8 digital
outputs, 4 digital inputs and 4 analog inputs), have the datasheet and
have also d/l-ed the ethersex code but no matter how hard I try, I do
not get a single packet received! EPKTCNT stays 0 even if I ping a
non-existent IP address (UC, MC, and BC are obviously ENabled!)
I have traced this back and I find that MARST is clear after a SOFT
RESET, while it should be set according to the datasheet! So I gather
that the MAC unit is not working.
My code looks like this (I hope the function names are self-explanatory):
/* Wait for ESTAT.CLKRDY */
while (!ENC28J60_RCR(REG_ESTAT) & (1 << 0))
CS_low();
SPI_send(0xff);
CS_high();
_delay_ms(10);
ENC28J60_Bank(2);
b = ENC28J60_RCR(REG_MACON2);
USART_puthex(b); USART_Transmit('\r'); USART_Transmit('\n');
The output is "00", with and without the delay.
When I initialize the remaining registers (ERXST(HL), ...) I can read
them back and they come out as I write them, so my access code should be OK.
I have also hooked up a logic analyzer to CS and the SPI lines and I see
that CS goes low, the 8 clock pulses with SI staying high, then CS goes
back high, so the soft reset really leaves the ATMEGA32.
Any hints?
Thanks in advance,
Josef
Josef Moellers
Oh, this is so emberassing.
CS_low();
SPI_send(0xff);
CS_high();
_delay_ms(10);
ENC28J60_Bank(2);
Any hints?
Yes:
"If the address specifies one of the MAC or MII registers,
a dummy byte will first be shifted out the SO pin. After
the dummy byte, the data will be shifted out MSb first
on the SO pin."
So rather than "SPI_send(RCR | MACON2); macon2 = SPI_send(0);" I have to
do "SPI_send(RCR | MACON2); SPI_send(0); macon2 = SPI_send(0);"
*then* the MARST bit comes out set!
Why I still do not see packets coming in is my next concern.
Thanks in advance,
No worries, mate!
Josef
Josef Moellers
Another followup to self:
Yes:
on the SO pin."
I had inadvertedly set LOOPBK in MACON1, effectively short-circuiting
the chip. That will teach me not to use symbolic names ;-)
I finally received some packets and already dumped one. It was great
seeing MAC- and IP-address of a host in my network.
Josef
