Björn
- Jan 1, 1970
- 0
A chip (a small digital radio reciever chip) should have 5 volts and
4,5 mA according to its specifications. Now, if it had 1111 ohm of
inner resistance, I would only need to connect it to a 5 volt battery,
and the current would be 5/1111 = 0,0045. If the inner resistance had
been smaller, I could've used external resistors to arrive at the
target current and voltage. Not a problem.
However, I measure the inner resistance of the reciever to 18000 ohm.
Since 5/18000 = 0,00028 (0,28 mA) and 18000*0,0045 = 81 volt, I cannot
achieve the specified voltage and current, can I?
This is of course a very basic question. Anyone who has connected
anything to anything must have had the same problem, and found a
clever solution which unfortunately escapes me
Should I maybe
ignore the inner resistance I've measured (when the chip is off, of
course) and just put 5 volt between the VCC and GND pins? But then,
what's the point with specifying a current in the first place?
