MRW
- Jan 1, 1970
- 0
Hello again!
Let me put some links before I start my question.
Image:
http://img79.imageshack.us/img79/9045/oscopeoutfilterxg7.jpg
Texas Instruments filter wizard:
http://www-k.ext.ti.com/SRVS/Data/ti/KnowledgeBases/analog/document/faqs/fwizard.htm
I decided to replicate the 2-pole high pass filter given by the TI
wizard (also seen in the image link). I picked a cut off frequency of
20 Hz and C = 1 uF. I calculated the R to be about 7958 ohms, so my R1
and R2 values were: 3716 ohms and 16791 ohms. I used one of the opamps
of the LMT324N quad opamp IC; I couldn't find the datasheet for this so
I used the LM324's.
For my VCC, I used a 3V output from a DC power supply. For VCC/2, I
used 1.5V from another output of the DC power supply. My input signal
came from a soundcard output. I used a program called DAQGen to
generate the 1kHz tone.
I measured my component values and they came fairly close to the design
values. However, when I connect the sound card output to the filter
input, my 1 kHz sine wave gets distorted. You can see it in the image
link. I am wondering what causes this.
I read in the Art of Electronics book that if I see some spikes on my
sinewave, then it is an indication that I may have some unintentional
capacitive coupling from a square wave. But I don't think I have any
square wave signals. Also, the spikes seem to be occurring
approximately every 450us (~2222 Hz).
What would cause my signal to get this kind of distortion when I plug
it into the filter input?
Thanks!
Image:
I used the LM324's.
Thanks!
