Installing Battery Charger - Where's the Fuse?
Sir Spamalot
I'm installing a new 20A intelligent shore powered battery charger.
The charger is located about 15 feet (wire run length) from the
battery box, separated by a bulkhead.
On which end of the wire run should the overcurrent protection go?
TIA,
SS
Peter Bennett
TIA,
SS
I'd put it close to the battery - that's where the serious fault
current will come from if you get a short in the wiring.
Larry W4CSC
On the BATTERY end.....to protect the boat from fire caused by the wire
shorting the battery, which is FAR more powerful than the charger.
